Fault Code P0599 / Thermostat Location
Hi everyone,
I am getting a generic fault code P0599 for Thermostat fault, I think the way its detected is via load voltage, when the computer detects no load, it thinks the thermostat not working. I am getting no heating issue which if the thermostat really not working, it could be on the full open position when it stopped working.
I though i check the thermostat connector before I raise it with the local Jag dealer.
The engine is pretty covered up and I haven't been under the car yet, only got it 4 weeks now.
Could anyone post photos or schematics showing the location of the thermostat on a V6 F-Type?
First, your generic code reader may not be telling you the real story. Since all F-Types should still be covered by warranty, you should take it to the dealer so they can check it with Jag-specific diagnostic equipment . Second, if you start taking things apart and damage something, you run the risk that problems you cause won't be covered under warranty.
Agree
Definitely not planning to undo a single bolt. Was just wondering if the thermostat connector is accessible so i can make sure it's plugged well and save myself the trip to jaguar.
OkieTim
09-08-2015 04:48 PM
