Filling fuel tank
Back to the issue at hand...the TSB is something that they should be able to do with a little notice...not sure if it is a while you wait thing though- I had it done while in for other work.
Interestingly enough, I had no problems, for the most part, until around 55K miles and then it started cutting off early. Since I almost always filled at not just the same station but literally the same pump, I mentioned it and the local dealership fixed it via the TSB procedures.
However, the way it was described, it was something that could be done while cooling the heels for an hour and looking at inventory on hand.
Many of them are just homemade. This one is made by a motorcycle accessory company.
https://www.aerostich.com/aluminum-g...ozzle-key.html
This tool from the same company looks better. Plastic, won't scratch.
https://www.aerostich.com/gascard.html
However, the new nozzles at my gas station work differently. The nozzle MUST be inserted far enough into the filler to push a thin cone back towards the handle.
I'll take a picture later...
rf69
10-14-2016 03:47 PM
amcdonal86
01-19-2012 10:00 PM
