Filling fuel tank
Old 05-13-2021, 05:21 PM
mbelanger's Avatar
Back to the issue at hand...the TSB is something that they should be able to do with a little notice...not sure if it is a while you wait thing though- I had it done while in for other work.
Interestingly enough, I had no problems, for the most part, until around 55K miles and then it started cutting off early. Since I almost always filled at not just the same station but literally the same pump, I mentioned it and the local dealership fixed it via the TSB procedures.
Old 05-13-2021, 06:01 PM
eeeeek's Avatar
The TSB requires them to order parts, so you have to set up the appointment in advance.
Old 05-14-2021, 05:22 PM
mbelanger's Avatar
Hence my reference to 'a little notice.'
However, the way it was described, it was something that could be done while cooling the heels for an hour and looking at inventory on hand.
Old 05-17-2021, 01:10 PM
schuss's Avatar
Welcome to the world of the motorcyclist in California. They actually make little tools to hold the shroud back so we can fill the tanks on our bikes.
What are those tools called?
Old 05-17-2021, 01:40 PM
eeeeek's Avatar
Many of them are just homemade. This one is made by a motorcycle accessory company.
https://www.aerostich.com/aluminum-g...ozzle-key.html
Old 05-17-2021, 03:52 PM
Carbuff2's Avatar
This tool from the same company looks better. Plastic, won't scratch.
https://www.aerostich.com/gascard.html
However, the new nozzles at my gas station work differently. The nozzle MUST be inserted far enough into the filler to push a thin cone back towards the handle.
I'll take a picture later...
carealtor
05-15-2021 03:55 AM
SJones
10-31-2019 12:20 AM
rf69
10-14-2016 03:47 PM
Bobman
04-12-2015 10:59 PM
amcdonal86
01-19-2012 10:00 PM
Quick Reply: Filling fuel tank
