Fire extinguisher mounting?
Old 07-05-2016, 12:29 PM
Tel's Avatar
Tel
Tel is offline
Default Fire extinguisher mounting?
Having a little dilemma here; I have a foam extinguisher to mount under the front of the passenger side seat. Been looking at fabbing up a bracket myself to hold it in position, however I have found a company that sells just the bracket at a reasonable price:
Fire Extinguisher Mounting Bracket - C2S35864 - Genuine Jaguar at www.rimmerbros.co.uk
Problem is, I have taken the seat all the ways back and tilted it up, but I can't find the holes mentioned in the instructions to mount to, so have not bothered to buy the bracket just yet.
I can see the black box (ECU?) under the passenger seat, but no holes to be found, unless I remove two hefty looking Torx bolts up under the frame?
I may have the wrong instructions.
Any suggestions would be helpful...thanks.
Old 07-05-2016, 12:40 PM
Tel's Avatar
Tel
Tel is offline
Bad day:
a) I can't spell Fire!
b) I may not have pulled the seat cover back to expose the holes!
Time for a beer ;-)
Old 07-05-2016, 02:18 PM
Unhingd's Avatar
Received 4,664 Likes on 3,369 Posts
Looks like you need to remove the passenger seat to properly install the bracket:
File Type: pdf
Old 07-05-2016, 05:29 PM
polarisnavyxj's Avatar
Default Get yourself some good insurance.
If my car catches afire, the last thing I want to do is save it.
The following 4 users liked this post by polarisnavyxj:
jaguny (07-05-2016), NoScurdyJags (07-07-2017), Panthro (07-15-2017), schraderade (07-18-2016)
Old 07-05-2016, 05:57 PM
jaguny's Avatar
When I was just out of college saw my boss's Porsche go up in flames. Not pretty. It was only a 944 though.
Old 07-05-2016, 06:27 PM
Unhingd's Avatar
The point isn't to save the car, but to give you enough time to pull somebody out of a car to save them.
Don1954 (01-17-2018)
Old 07-05-2016, 06:44 PM
Received 4,464 Likes on 2,427 Posts
Consider mounting the extinguisher to the drivers seat instead, I've done this on my XJR, it's easier to reach but still out of the way. Because if you need it, you want to be able to reach it easily.
Panthro (07-16-2016)
Old 07-05-2016, 07:11 PM
Unhingd's Avatar
Attachment 132737
Cambo, looking at the instructions, it implies the fire extinguisher should be mounted on the right side of the car regardless of whether it is RHD or LHD. If not true, please advise, as under the driver seat would indeed be preferable. Thanks.
Old 07-05-2016, 07:27 PM
The factory bracket fits both seats as far as I know. It's the same bracket used on the XF, XK, and ever my older XJ. The mounting holes are there on both seats in my XJR.
The following 2 users liked this post by Cambo:
Panthro (07-16-2016), Unhingd (07-05-2016)
Old 07-06-2016, 08:38 PM
lizzardo's Avatar
Received 1,000 Likes on 747 Posts
I got the Jaguar kit and installed it on the driver's side.
Sorry, can't provide any pictures. Maybe in a couple of months
The extinguisher that came with the kit had no latch (probably a manufacturing defect on the cradle), but I swapped it for another I had that did. It's a little smaller, so I don't bump it as much with my heel getting in.
Old 07-07-2016, 11:46 AM
Tel's Avatar
Tel
Tel is offline
Thanks for all the replies.
The aim here is to have it onboard as a preventative measure; not necessarily for me, but if I was in a queue of traffic and the car in front caught fire, which could possibly spread to mine, at least I could have a go at saving their car and stop it spreading to mine.
I purchased a 2 L Foam type as powder messes up a lot of stuff, and the external diameter is around 4'', so it will be tight. It comes with its' own holder and strap.
I have felt up and inside the seat squab cover and located the two mounting holes pictured in the .pdf that you have put in the thread - thanks again for that.
The part that I require is the bracket between the seat and the extinguisher (I can drill more holes n the bracket if need be to align with my bigger extinguisher's holder.
I'm not sure if the .pdf though, is for the F-Type as these instructions show another two supporting brackets that run vertically and pickup on another two holes directly under the seat squab.
The picture of the bracket that comes from a .pdf I found on the net shows just two holes are used??? See attached .pdf.
I think that I require Item H only?
If anyone can clarify I would be grateful.
File Type: pdf
Old 07-17-2016, 09:57 PM
Items A and H in that instruction do the same job as far as I can tell. It's most likely that the sub-supplier was changed and therefore the design changed as well.
Years ago when I/we were putting the extinguishers in the XJR's (did two cars at the same time) the OEM bracket type A was out of stock from Jag and couldn't be ordered. So my friend James with the other XJR made the brackets from sheet metal instead. Copying the design of the OEM brackets.
The fabricated brackets in our cars look more or less the same as the item H in the PDF.
I don't think A & H are meant to be used together, they are doing the exact same job, ours are only mounted by the two bolts, nothing more. My take on it is that the A was the original design, which was sold out, and then the new design is the H, which does the same job.
Old 07-17-2016, 11:00 PM
lizzardo's Avatar
The kit I got included both A and H, but only one was needed.
Old 07-17-2016, 11:09 PM
Ah ok, that explains it then...
They both do the same job right?
Old 07-17-2016, 11:54 PM
lizzardo's Avatar
Yes. I'm not sure why both were included, since either would have fit for the F-Type. My guess is that some models covered by the kit require one or the other. My recollection is that there were two possible positions with the one I used. Someday I'll get my car back and will be able to provide better information then.
Old 07-18-2016, 03:28 PM
Tel's Avatar
Tel
Tel is offline
Thanks for the replies - It looks like Item H is the piece I'm after, I just need to find out the Part number and also if it can be ordered/purchased separately?
From what I can make out, H allows you to mount the extinguisher bracket to the seat bracket with a slight offset either left or right depending on the length of the nozzle/handle assy.
The other bracket, I think must be for vertical mounting, or mounting in another model car that has plenty of room below the front of the seat to allow for the length of the extinguisher.
Old 07-18-2016, 08:27 PM
lizzardo's Avatar
Yes, just two bolts hold the bracket to the seat frame.
I think I used Bracket A for mine, but it's a smaller extinguisher than the one that came with the kit. Bracket H would work too, and may be required for an extinguisher than large. The one that came with the kit is 3.5" in diameter and when I test fit it I kept hitting it getting in and out of the car.
Old 07-29-2016, 01:30 PM
Awd's Avatar
Awd
Awd is offline
What was the source of the extinguisher / mount ? Price ?
Thanks,
Alan
Old 07-29-2016, 02:14 PM
lizzardo's Avatar
The kit we're talking about here is a Genuine Jaguar Accessory, with a Genuine Jaguar Price: $200.
The kit comes with two brackets because it fits several models. I still am without the car but I was doing some cleaning and found the rest of the kit. The bracket labeled "H" is the one I used, and the bag it was in has a number, "ASG 11366". If that means anything as an individual part, I hope someone finds it useful.
Old 07-05-2017, 09:45 AM
Awd's Avatar
Awd
Awd is offline
Has anyone tried thebracketeer.com bracket....it's $60 and seems well engineered and compatible with many seats. I'm a bit concerned about the "black box" at the front of our power sears. ( I have the sport seats...FTypeR )
Thanks,
Alan
Quick Reply: Fire extinguisher mounting?
