The first 500 to 1000 kms
Lawrence.
Hmmm.... Under Pg. 147 of my Owners Handbook, under "Maintenance." Also called "Running-In." (While I have the V-8, the Owners Handbook lists both the V-6 and V-8, so I assume the break-in process is similar for both engines.)
The Handbook calls for a 2-stage break-in process for 2,000 mi (3,000km). The first 1,200 miles (2,000km) not exceeding 4500 rpm or full-throttle starts among other things. From 1,200 miles to 2,000 miles, increasing road speeds gradually and engine rpm's in excess of 5,000rpm for brief periods.
On proper break-in, there are two mainstream schools of thought: (1) Drive it like you stole it, aka "run it hard"; and, (2) Follow the manufact's instructions, aka "go easy" for the first few thousand miles.
The first method of break-in, "Revving the daylights out of the engine from the start" is certainly controversial. But, there is the belief out there among many that optimum ring seal (read: Maximizing an engine's HP/Torque) is achieved by many short bursts of hard accel/decel. See here for one synopsis on the theory: Break In Secrets--How To Break In New Motorcycle and Car Engines For More Power
For me, I use the second method, following the manufact's instructions. But, I do make it a point to vary the engine speeds as much as possible by using the Sport Mode/paddles as much as I can, especially in traffic.
However one breaks-in their motor, most every (if not all) manufact tests their engines in some way before we ever get our hands on them. Having a "pure" motor without ANY runtime doesn't seem to happen much (unlike the situation where one builds their own motor and runs it for the first time).
To address your last point, I don't think "Dynamic Mode" hurts break-in per se--if you don't use it to its full capability until past the 2,000 miles mark. (But, it's tempting, isn't it?)
user 467478 (06-26-2014)
X308XJR
05-20-2019 06:50 PM
