First Check Engine light Need Help
Old 12-14-2018 | 12:58 PM
StormtrooperFtype's Avatar
Exclamation First Check Engine light Need Help
Hey folks, was driving last night, making some pops in 2nd and 3rd gear, put the car back in D and all of a sudden Check engine light started Flashing, all of a sudden had a mini heart attack put my hazards on and I had to move across 4 lanes to pull over, i go to give some gas and the car starts to stutter and bog down, about 20 seconds later of limping it over to the side, I put the car in park and it starts to idle roughly and jump in down between 800-1700 rpms, shut the car down, say a quick prayer, start it up again, no check engine light, idling perfectly fine, drive it around calmly for about 10 minute, and then do another little pull to see if its all right, car seemed perfect, but did seem like it was crackling and popping a little less, took it home, this morning drove it, all back to normal. I've had the car for a little over a week, only put 93 from good gas stations, Definitely had my share of fun but nothing crazy. I do want to put in my car backfires ridiculously, more then any other Stock F type ive heard, I do the trick where very small taps of the throttle, and i'm not sure if Im just good at it, but I've made some crazy pops, and I do, do that a lot, not sure if that matters. Any help or Advice would be greatly appreciated, thank you all in advance.
Old 12-14-2018 | 01:30 PM
DJS's Avatar
DJS
Someone should read the OBD codes to see what caused it, if possible.
Carbuff2 (12-15-2018)
kmmoore1013
07-28-2013 05:31 PM
srpope80
11-17-2011 05:06 PM
AaronnJones
09-12-2011 07:12 PM
YTC
04-19-2009 07:26 PM
Quick Reply: First Check Engine light Need Help
