First oil change
#81
This link goes more to racing; still, there's a few useful on-topic nuggets: Racing Oil vs. Street Oil: Know the Differences - EngineLabs
"Follow the engine manufacturers recommendations with regard to the weight of the oil you run."
“Whether you realize it or not, you build your engine around the oil so matching viscosity and clearances is critical.”
"Viscosity must be properly matched to the engine’s clearances and operating conditions to optimize performance."
"...heavy viscosity grade engine oil does not automatically equal better protection."
#82
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
Both links posted in this thread were written by the same expert. If you're a bright guy and invest a fair amount of time studying what he clearly explains, it should no longer be a mystery to you.
However, for the average bright person, the easiest and "smartest" strategy is to accept that the manufacturer has done extensive testing and knows far more about what's best for your engine in normal street use than you do. Obviously, with longer and longer powertrain warranties now essentially standard, the last thing in the world they can afford is making the wrong oil choice. If they do, they pay the price.
If you still can't accept the above rationale, then just accept the fact that if you use something other than what they recommend and you have a problem, then you'll likely eat the cost of replacing your engine.
It's also important to remember that they sold you a car intended for street use, and if your primary use is on the race track, you'll also have to accept the consequences.
#83
Me too, but IMO this is all street use. Spirited street driving is a far cry from the intense level of even a simple track day. Normal oil requirements are sufficient for frequent spirited street use.
Ubad2 (01-10-2016)
#84
Received 2,263 Likes
Yes, my use will be probably 80% street use. There will be occasional race situations on empty highway roads so I wondered if the extreme motor heat would break down the oil as its not a heavy grade oil. Your right, keep it as is, and if anything goes wrong it's on Jaguar's shoulders not mine.
#85
I'm under the belief that the heavier grade oil can withstand a higher heat level, thus the higher oil grade number on bottle. Otherwise what's the point of using a oil like 10w-60.
No ... ???
#86
No.
The number on the bottle is an indication of the oil's viscosity at a set test temperature ~210F I think. The oil will still fall apart at a given temp irrespective of the viscosity.
Generally synthetic oils have a higher maximum temp than conventional oils if excessive heat is a concern.
I have no idea why people want to use 10W60.
#87
For those with the 5.0, have you done an oil analysis yet?
I sent a sample to Blackstone and found out they do not have any averages for the V8 which is surprising considering they are one of the leading oil analysis companies in the US.
I have attached my analysis and I will basically invalidate it due to me not grabbing the sample when I drained so I have no idea where in the drain the sample came from, early or late in the drain can increase the amount of metals and throw off the results.
That being said I will be changing the oil every 7500 miles and will send another sample in for analysis.
#88
https://www.jaguarforums.com/forum/a...5-2014-016.pdf
aholbro1
08-05-2021 05:02 AM
