First oil change inquiry ?
Old 05-10-2016, 09:13 PM
Unhingd's Avatar
Received 4,661 Likes on 3,366 Posts
Originally Posted by SinF
Unlike other theories in this thread, simple oil analysis shows that your theory is not true. They do fill each car with "this stuff and send it to the dealers". Also oil additives like ZDDP might be harmful to your engine, while I use it with flat tappet engines in my classic cars, I wouldn't put it into modern car, especially one that uses 0w20 oil.
+1. Same oil put in at the factory as found in the 0W-20 bottle.
  #142
Old 05-10-2016, 10:54 PM
Foosh's Avatar
Received 1,028 Likes on 854 Posts
Yes, and we will see recall and/or recommended service period changed in a couple years once sludge becomes well-known issue. This is lifetime fill transmissions all over. I am really surprised that you do not see it this way. I had to pay for a new transmission, that cost would have purchased couple lifetimes of transmission fluid changes. Original transmission lasted to about 120,000km with no oil changes; replacement used (!) transmission was still going at 400,000km when I gave away the car with bi-annual oil changes.
Really . . . there you go again with cherry-picked sentence quotes out of context. Now annual oil change requirements are like lifetime, no change transmission oil?
And what is it you're surprised I don't see? One more time--what I said is I don't see any credible scientific evidence that more frequent oil changes will solve the particular timing chain wear issues now being linked to GDI engine designs. The evidence that does exist simply suggests that today's best oils may not provide adequate protection for today's GDI engines. No data have surfaced on optimal oil change intervals for GDI engines.
I also said I experienced excessive carbon build-up on the valves of my GDI 4.2 V8 in an '07 Audi RS4. That car received oil changes at an Audi dealer with the recommended Audi oil every 3K miles. I dumped it shortly after 20K miles because it had multiple other "issues."
And, just for the record, in a couple of weeks, my F-Type will receive it's 3rd fill of fresh oil in 9K miles.
  #143
Old 05-10-2016, 11:52 PM
Queen and Country's Avatar
Received 2,383 Likes on 1,609 Posts
Originally Posted by Foosh
It would be fair to say it is a "promising hypothesis," but the history of science and engineering is littered with debunked promising hypotheses.
There have been far more blunders in automotive design and recommendations than debunked hypothesis of consumers. in fact its the other way around, consumers are the test guinea pigs. The only way Jaguar found out that 0w20 was the right oil viscosity for the DI AJ133 engine was to let the early adopter dummies like me use 5w20 for 5 years. I am not convinced they still have it right. SinF is right, there will be lots more changes down the road.
  #144
Old 05-11-2016, 12:42 AM
A thing to keep in mind is that until recently manufacturers did not even know that there is a monster called carbon nano-particle eating away engine components. And you have to also answer, did you? many of the remedies like oil catch cans, bypass oil filters were discovered and first used by us consumers. Because even when they do find there is a problem, they only fix it in subsequent designs.
  #145
Old 05-11-2016, 07:25 AM
SinF's Avatar
Received 2,141 Likes on 1,461 Posts
Speaking of, anyone installed oil catch can on F-type, and if so how much collects between oil changes?
  #146
Old 05-17-2016, 09:32 AM
Absolutely not true. it is clear the problem is just not very well understood, and there is absolutely no evidence YET that shortening the oil change interval will correct the problem.
Bad news ole chap. GM has concluded that shortening the oil change interval is required in preventing timing chain wear.
They have gone as far as to issue a recall and reprogram the onboard oil computer to remind of oil changes much sooner than previous. (Half the time by some accounts- down to 5k from 11k)
Bear in mind, typically, 20+ people have to lose their lives before OEMs fess-up or they have to be on the hook for the liability- as GM was since its their computer telling folks when its best to change oil.
SinF (05-17-2016)
  #147
Old 05-17-2016, 11:04 AM
Foosh's Avatar
Bad news? No, not as far as I'm concerned, but a reference would be nice. Do you have one?
You still seem to be having trouble understanding the position I have taken in this thread. I am agnostic about whether oil change intervals should be changed or not, absent compelling evidence of benefits. I would welcome new evidence one way or the other.
  #148
Old 05-17-2016, 11:36 AM
I was truly agnostic whether oil change interval made a difference or not. You were adamant there was no evidence supporting more frequent oil changes than originally prescribed. Even though both hands of intuition and science pointed at soot loading.
I cannot believe you are asking me for a reference. We should have asked you if you had any evidence of your absolute claim that there was no evidence supporting reducing oil change frequency reduced timing chain wear. I did my due diligence and reporting back that there is tons of it.
But again I assert that this is about timing chain wear for me and not OCI. I would like to discuss additional methods of reducing it.
  #149
Old 05-17-2016, 12:24 PM
SinF's Avatar
Actually, the onus to provide evidence is on you Q&C since your position that status quo must change. (and I do agree it must change)
  #150
Old 05-17-2016, 01:00 PM
I'll do it with the protest and preface that we should make note on how we humans take a stance based on emotions and not facts. Its a good thing I chose to verify. The evidence exists as far back as 2010!
In a letter to customers and dealers. Note GM cars come with a sophisticated system for determining oil life. Obviously, even it was unaware of the soot loading problem in DI- which is the only engine this recall was issued for, across the board. Also note their apology for ingnition shutdown was not this unambiguous.
"We have determined that under certain driving conditions, and with extended oil change intervals, the timing chain could wear prematurely and cause the illumination of the Service Engine Soon light. Timing chain wear can be affected by the age of the engine oil and driving conditions.
What We Will Do:
To ensure that your vehicle will not experience this condition, your GM
dealer will change the calibration of the engine control module, including the engine oil life monitor, which in most cases will recommend more frequent oil changes. This calibration
change will be performed for you at no charge until February 28, 2013."
  #151
Old 05-17-2016, 04:45 PM
Received 2,263 Likes on 1,845 Posts
Aren't you the guy that just berated me for quoting experience from one Jag model and applying it to another?
The GM engine you refer to above is a 3.6L V6 that is available in both DI and non-DI versions in a wide variety of vehicles.
So it's not a Jag engine and not a V8 and in most cases not DI, but we're supposed to accept that this is credible technical substantiation that can be applied directly to the Jag V8 with DI.
Sure...............
  #152
Old 05-17-2016, 07:51 PM
Mulmur's Avatar
I wonder that this may have become a rather 'circular' argument or another way to look at it, is it possible for someone to be in a room by themselves and still start and maintain an argument.
Lawrence
The following 2 users liked this post by Mulmur:
Foosh (05-17-2016), Mbourne (05-17-2016)
  #153
Old 05-17-2016, 08:12 PM
Mbourne's Avatar
Lawrence
reminds me of the old Monty Python sketch.
  #154
Old 05-17-2016, 08:22 PM
lizzardo's Avatar
No it doesn't.
  #155
Old 05-17-2016, 08:31 PM
Mbourne's Avatar
Originally Posted by lizzardo
No it doesn't.
  #156
Old 05-17-2016, 08:56 PM
Hopefully he only paid for the five minute argument and not the full half hour.
  #157
Old 05-17-2016, 09:48 PM
Unhingd's Avatar
Like my parrot, this discussion is bereft of life.
  #158
Old 05-18-2016, 05:34 AM
JohnnyRotten666's Avatar
I started this post with a simple inquiry about service intervals. It escalated (or degraded) to a technological pissing contest. I'm old enough to remember when "manufacturers" said smoke Camel non filters they'll cure that sore throat. I don't trust JLR. Their recommendation will certainly get you through to the warranty period with the least expense on their part as possible. I think I'll just change my oil at 5000 mile intervals thank you.
The following 2 users liked this post by JohnnyRotten666:
Queen and Country (05-18-2016), SinF (05-18-2016)
  #159
Old 05-18-2016, 07:38 AM
SinF's Avatar
I don't think anyone in this thread actually changes oil at full JLR recommended interval, not even people that do oil analysis. So it is rather strange that some individuals give Q&C such hard time over what is in my mind a plausible (but not definitively proven) theory as to why shorter change intervals are absolutely necessary.
Personally, I am about to hit 5000km and scheduled my second oil change.
  #160
Old 05-18-2016, 08:28 AM
Foosh's Avatar
This is my last attempt to try to explain, after which I'm exiting this discussion once and for all. It has become completely circular and arcane.
The reason "some individuals" like myself have questioned Q&C's rather strident pronouncements is that there is no evidence that more frequent oil changes will resolve timing chain issues seen in certain DI engines. As clearly stated in his own posted references, many experts believe that it may be a shortcoming w/ current oils (clean or dirty), period.
It is a plausible theory, but it is an unproven one. Maybe shorter intervals will prolong the life of timing chains, maybe they won't, but it's just pure speculation at this point. I can see why some manufacturers may have decided to change their recommendations because it's worth a shot to see if it helps.
I also change my oil about every 5K miles, but I have no evidence that I'm gaining any benefit from that. However, I'm willing to pay extra, much like purchasing insurance that I probably will never need.
There's also no evidence that GM's move to shorten their recommended oil change interval for certain engines has resolved their problems. In fact, in looking through the articles written regarding the GM problem last night, it appears that not even GM thinks it's a definitive solution. Subsequent to the problem being identified several years ago, they have discontinued some of the involved engines, and substantially redesigned others.
SinF (05-18-2016)
Quick Reply: First oil change inquiry ?
