First startup and drive after 5 winter months
The car was placed in the (not heated) garage late october last year. Winter preparation was clean and dry car, new engine oil, increased tire pressure (50 pounds), full tank, indoor car cover and a sock full of dry rice inside cabin (to soak up moisture).
I have charged the battery once every 6-8 weeks (last time was 4 weeks ago). I have not been into the car (not opened any doors except for the rear hatch when connecting the battery charger), windows have been closed.
The winter has been unusually long and hard. Temperaturs have mostly been below zero celsius, and often below - 10 to - 15 celsius for extended periodes.
Today it was + 4 celsius, and there is still snow on the side of the roads. The roads are clear of snow but with lots of gritts and stone pebbles, but I could not wait any longer to start it up and drive for a short trip to see if everything worked well.
Removed the cover and it looked great. No humidity inside the cabin, no bad smell, doors, windows, mirrors and steering wheel moved easilly without any hesitation or "strange" sounds.
Pushed the start button and the engine started without any hesitation. The exaust walve closed after initial startup (also without any "strange" sounds), engine sounded good. Put it into reverse and backed out of the garage. Brakes did not "hang" (it was parked on level surface without engaging the el. park brake). Let out the extra air pressure from the tires, and drove off.
No flat spots could be felt from the tires. The first gearshifts were maybe a bit more "harsh" than I could remember, but everything felt normal after a few shifts.
It felt SO good to drive the car after the long winter, but I only drove a few miles due to the bad conditions of the roads. The traction was lousy due to pebbles, dirt and cold weather, so the rear tires broke loose everytime I gave some gas. I know you all knows it, but this car has some serious low end grunts
I checked the oil level after the trip, and it was spot on at the full level mark (as it was when I put it away for winter). I also checked the garage floor when the car was out, and no signs of any leaks from engine or differential.
So to sum it up, the F-type seems to have taken the long hibernation very well, but the roads needs to be cleaned and the weather warmer, before I can start to really appreciate some good drives. Hopefully that won't be too long, and both the car and I are very ready for it
The following 6 users liked this post by Arne:
Buckingham (04-07-2018),
DPelletier (04-20-2018),
malbec (04-07-2018),
Mbourne (04-09-2018),
Tayls77 (04-12-2018),
and 1 others liked this post.
Sounds similar to my experience last week here in the never ending winter when I brought mine out of hibernation. Similar storage condition, except no rice. I did use clothes dryer softner sheets in various places to ward off rodents. Did your rotors have a bit of surface rust?
+2. Pulled mine out last weekend. Did one nice hour+ top-down cruise, but otherwise, weather has been crap.
Mine was stored in a barn. Cheap car cover under zip-up Rhino car envelope. Sprinkled a box of mothballs around the car - no rodent issues.
Battery was dead in the remote, so replaced batteries in both remotes.
They do rust quickly after (even during...) a wash though, so I have gotten used to the "after wash braking" prosedure
I plan on never selling my R neither, and have also treated the underbody with a "light" anti-corotion application, even though it is not used during winter.
Glad to have (almost) everyone back on the prowl. I can't image having to do without the F-Type for 5 months and very glad to have moved out of Connecticut.
I have a couple of spare parking spots for anyone who'd like to winter over in the unfrozen south. Bring your clubs and you can get a round in at Pinehurst while you're at it. (That probably wouldn't work well for Arne, though.)
Took mine out of storage a few weeks ago and have been out with the top down with the heated seats and steering wheel, and heater on full blast. The sound is so much better with the top down.
Received 3,259 Likes
That is self-imposed punishment. I'm just 70 miles to the south of you and have had mine out and about all winter. Get with the program!
I must admit, with Spring being rescheduled to a later date this year in the upper Midwest, I am long past my tolerance level albeit a snow-covered earth. For many years I have lived by the principle that I shan’t drive on salt encrusted roads, however I don’t think I can make it past this weekend. The current scheduled weather is 39F/4C for Saturday, but with desperation well established, the rational for this principle is waning. I have the climate pack after all, and there is that snowflake button, obviously they expected it to be driven in these conditions.
