First Time JLR Owner - Forum Introduction and Build Thread
Have you inspected the cooling system for leaks? I don't see the mileage listed for the vehicle, but if it hasn't been replaced, the rear heater pipe between the cylinder heads is a common failure point that can lead to catastrophic engine damage.
Another area to inspect is the outlet pipe under the front of the supercharger and thermostat housing on the AJ133, which are also subject to leaks.
I have an appointment at the dealer early next month to address what I suspect to be an issue with the telematics (bad key fob range and abnormal battery drain). I will be sure to get a second inspection from them as well.
MovesLike, can you DM me? I am seeing this car listed for sale currently. I don't think the seller is you, since it seems you sold it last year. The seller is using pics from the car's old BaT auction, triggering my scam sense. The seller isn't answering, but I'm trying to determine if the listing is legit and, if so, how to reach the seller. Thank you!
Ranger0fThNorth (01-20-2024)
