Fitting rear blackvue camera
Hi
Purchased a Blackvue 650 front and rear camera set for recording journeys and incidents. Any suggestions on how to run the cable from the rear to the front?
Front camera is installed behind the rear view mirror, and rear camera is installed centrally at top of glass.
HD quality is good, and easy to view on iPhone using Blackvue app.
David
David
Hi
David
David
I'm afraid I can't help with suggestions, but I did want to give you a heads up about a potential issue with the mounting of your front camera.
Questions... Do you have auto dimming high beams? If so, have you driven at night yet with the new camera mounted?
I recently attached a suction cup mount to the windscreen directly below (in front of) the rearview mirror (to hold an iPhone). During the day, all was fine, but the first time I went out at night, I started getting all sorts of odd error messages on my console until I realized the mount was directly in the path of the forward facing light sensor on the front of the rearview mirror that detects oncoming vehicles and auto-dips your high beams. I remove the suction mount and all the errors cleared immediately.
It might not affect you, but you might like to check it out.
Cheers,
Oz
![Icon Laugh](https://www.jaguarforums.com/forum/images/smilies/icon_laugh.gif)
So, have pushed the wires up into the roof lining across the front of the windscreen, between the upright and roof joint and then behind the rubber door seal all the way to the rear. I've taken the power the same route and then dropped that down behind the seat to use the 12V socket in the centre console. May try and find a route under the plastic trim into the centre console when I have a moment.
KarimPA
09-12-2015 08:15 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
