Fixed big wing GT Spoiler for R coupe, opinions wanted please
Hi guys,
I want your opinion and thoughts on these two fixed rear wing spoilers. The first one is from PIECHA. The second spoiler is the PROJECT 7 rear wing spoiler. Which of the two spoilers looks better and more aggressive.
It's obvious the Piecha spoiler mounts by the rear trunk lid edge points based on photo.
Regarding the Project 7 spoiler, can this spoiler be attached to the F Type coupe as the two cars rear end area is different. What are your thoughts guys. Thank you.
Ubad2 (01-31-2016)
I believe the original question was which rear wing looks better, not do you like rear wings. Some ppl like, some don't. At any rate, I actually think they both look good. Would base decision including cost factor, downforce data (unless it's just for looks), ease to attach, other intangibles. My 2 cents worth.
Ubad2 (01-31-2016)
Would be odd if each person were to pick a "favourite", without also stating that their actual preference was neither.
Ubad2 (01-31-2016)
The two fixed spoilers you referred to look ok only because their lines are complimented by the diffuser which is not what you would already have on your coupe. So you may want to consider how these spoilers will look on your coupe sans the updated diffuser.
Also consider the SVR's spoiler - that may me more "appealing" on the coupe and may be a much easier fit. Also, the key in the SVR spoiler is that its much closer to the car (less air gap in between) and that helps with retaining the overall lines and presence of the car.
You will have to disable the existing deployable spoiler in the first place anyway.
Wing spoiler paint color ...
Thanks for your replies guys. One other question for you, if the car is storm grey, should wing spoiler be same as the car or should it be painted gloss black to stand out a bit. By the way, I decided the PIECHA wing spoiler is the way to go for the R coupe. Thanks for your feedback.
Ubad2 (02-05-2016)
