Flaking paint?
Just curious if anyone has ever filed any type of paint issue warranty repair.
Thanks for your responses gents.
DS
This type of paint failure has been covered under warranty for others and in most cases was caused by two body panels rubbing up against each other (typically where the lower rocker panel meets the rear body shell just behind the door. In your case, it looks like the headlamp washer is fitting too tightly into the bumper shell causing the clearcoat to chip off at the edges when they are deployed and retracted. Buffing won't solve the problem without reapplying clearcoat on the edges,.
Many thanks. 🤗
pdog2000
01-08-2011 01:26 AM
