Flappy Paddles
Flappy Paddles
So this is then first car I have had that has had these, being a long time fan of manual transmissions I want to like using the paddles and have been trying to get used to using them. I am beginning to get straight which side for up and which side for down without having to think about it.
But IMHO 8 speeds is really too many for manual changing, but the real thing I don't get is why they made the paddles move with the steering wheel, this makes it virtually impossible to change while turning as it quickly becomes confusing where the right paddle is and difficult to get you fingers to it. At least if they stayed still you would know which was the right paddle without having to think about where it is.
Do all cars with flappy paddles have them turn with the wheel or do some have them fixed to the steers column?
You're not supposed to shift IN the turn. Shifting in a turn can upset the weight transfer or even worse lock up rear wheels and cause a spin. Ideally you should be the proper gear before the turn.
I also do realize that I at least read the ZF will hold a gear if the system knows you're in a turn...
I know what you mean, but you can also use the shifter in sport mode. Once you have the steering angle dialed in, you simply reach for the shifter and give it a light pull it toward you for an upshift just as you did on a manual.
AnD3rew (04-12-2015)
It's more common to have them on the steering wheel. Granted, you will rarely be at full lock and also shifting at the same time, but you will be partially turning and shifting quite a bit. It's been found it's more predictable to have them turn with the wheel and most race cars have the same (F1, GT as above, etc).
IMO you don't want the paddles to stay stationary on the steering column, you want them moving with your hands so you don't need to move your hands from 9-3 to shift (unless your doing a tight turn, in which case, I agree with the others - you should be pretty well downshifted already). I've occasionally been caught out in the wrong gear and do what's been suggested - use the center shifter to grab a lower gear.)
Stick at it - it becomes more and more natural, and rewarding.
Perfect world scenario. May not work for you if 4 of you are entering the turn at the same time.
