Flashing Start / Stop button
I just got around to changing my scratched up engine start / stop button for a shiny new replacement, which looks much nicer. I seem to remember that the old button used to pulse red under some circumstances or other, though I can't remember when, whereas the new one doesn't seem to light up at all.
Did I dream the flashing red thing or is there some particular circumstance that I need to be in before it flashes?
Thanks!
Thanks!
Thanks!
Thanks!
Not dreaming, it should pulse red when you get in the car (car must recognize the key fob), prior to startup. I don't think they would've stopped the illumination/pulse with the new part designs. The last time I was loaned an F-Pace earlier this year, I recall the start/stop button did the same thing.
xrix4096 (08-20-2019)
https://twitter.com/jaguar/status/815164843338690560?lang=en-gb
David Meier (08-22-2019)
Pretty sure it will. It turned out to be my mistake, you just can't see the pulses in bright sunlight. BTW for button removal I found that pushing a bit of sewing thread into the gap around the outside of the black bezel and then pulling removed it easily without risk to the surrounding fascia, though I reckon the tip of a knife with a bit of tape on the fascia to protect it would also work with a bit of care.
David Meier (08-23-2019)
Carbuff2 (08-28-2019)
