Flat battery-getting into powered boot to get at battery
So my battery is flat. Trying to charge it from the front but not going well. Sounds like I need to remove the battery and have it tested or replace it. I can start the car now as it will not recognize my key. Even if put down by the sensor on the left. Remotes will not work to pop the boot nor will the button on the rear hatch. What is the trick?
If your battery is discharged too far a smart trickle charger or maintainer won't be able to recharge it because they battery voltage is too low - it either won't start to charge or take forever. Use a standard type dumb charger to charge it for 5 - 8 hours and you might have some luck unless the battery is indeed internally shorted or has a bad cell.
You need to use a battery charger on the engine compartment terminals. As previous, a trickle battery maintainer will not do the job.
Perhaps you need a new battery but with a long duration charge at high enough amps you will likely get enough juice into the battery to activate things.
Buying a decent full power charger is much cheaper and less likely to damage the car than a tow job!!
I use a CTEK on the front terminals and it works just fine as a maintainer.
Received 3,209 Likes
Something doesn't make sense or at least hasn't been fully explained.
How did you open a door to pop the hood if you don't even have enough battery power to pop the hatch?
Did you use the emergency key in the fob to open a door?
Usually when folks have a flat battery and can't open the hatch to access the battery they use that key to open a door then pop the hood then use a trickle charger/battery maintainer on the engine bay connections to get enough power into the battery to at least pop the hatch.
If you have another vehicle that you can hook up, at least briefly, to the terminals under the hood, you should get enough juice in the system for the button on the dash to pop the hatch even if it isn't enough to crank the engine. Been there, done that due to the dreaded OBD port drain at annual inspection time...
Leave your remote out of the opening process if you can help it.
Now I am pleased that my convertible has a manual trunk latch mechanism!!
Thought it was a bit cheap at first!
Though, on second thoughts, I am not sure whether the manual release button will operate the trunk release without power
I guess I will trust the CTEK!!
Not entirely true. Some OBD devices cause the problems, but not all. I've had dealers and independents plug into my OBD and never had the problem. Others have not been so lucky. The trick is to check the light in the hazard switch - if it hasn't gone out within about 10 minutes of locking the car, you're in trouble.
scm (03-05-2021)
It fixes all sorts of electrical issues....just pop your trunk, remove the +ve terminal for 10-30 seconds or even longer if you feel inclined, and bingo, everything is back to 'normal'. You will most probably have to reset your window roll up/dn function and the centre display, but that's it.
In MA they have to plug into the OBD port as well, so you could definitely see this issue after a MA inspection.
