Flickering LED's
I've seen that too, and not just on videos of the F-Type. It doesn't seem to flash consistently though, which makes me think its a trick of a video camera's refresh rate vs. LEDs cycle rate (some displays cycle leds off and on to modulate brightness and reduce total heat which can shorten the life of the diode). Its possible the LEDs in these cars are modulated also.
Usually thats a result of the light being a different frequency than the video camera can capture. Most cameras operate at a multiple of 30 frames per second, if the lights have a wavelength that is at odds with that rate then it will look like they are flickering in the video.
It's the same reason wheels sometimes look like they're spinning backwards in auto videos.
For some really insane light effects, including actual stroboscopic flickering lights, check out these crazy Japanese cars. Holographic wraps!!!
The customized Lamborghinis of Japan's underworld
goges
10-05-2015 04:53 PM
rsa760041
23
09-25-2015 01:33 PM
