Forged wheels, vap suspension wortec rotors set up.
I been reading through the old forums and seen many individuals went with wortec rotors and the 20x9 & 20x10.5 staggered options for rims. Seems like someone had to put 6 mm spacers in order for everything to fit with no rub or problems with calipers. Question is what is the ET for this option while not wanting to put spacers on?
Also out of curiosity Michelin ss 4s 255 and 295 tires will fit on this set up correct?
Thanks in advance.
Thanks in advance.
Everything you've mentioned is std sizes for 20" wheels and no you dont need spacers as all you'll be changing is the disc itself
calipers are the original calipers.
The et is specific to each individual aftermarket wheel mine for example is 17 rear and 34 front which are very extreme and push the wheel out inline with the
edge of the wheel arch.
Thanks in advance.
Thanks in advance.
but not anymore
Looks great as well
