Front of car squashed
They started it with fluids gushing out of it?! This is negligence on top of negligence. You can clearly see the pool of coolant and maybe oil on the floor. Then they drove it.
I'd push for it getting written off. If they try to fix it, insist shell/body gets laser measured, as the entire weight of the car was sitting on the front.
The garage is a Klaus machine and self-operated, so their are no operators, this is how parking works at my apartment. I have attached a youtube link below to show how the garage operates. In front of each parking spot is a little bump stops that informs the "parker" where to stop; however, it appears my bump stop was push too deep into the machine (since my car is low, I have a low profile bump-stop which is about 2" tall), anyways I ended up parking the car a bit too forward and I had no idea. The machine didn't complain at all and everything seemed good, until I returned from work and saw this. I had zero idea this would be the result of parking too far forward, I was not informed this was a possible outcome by the property manager, and I believe the machine should have sufficient sensors to detect an object preventing its safe operation.
Burt Gummer (01-18-2018)
"I believe the machine should have sufficient sensors to detect an object preventing its safe operation."
As any reasonable person would. Everyone's cheesy home garage door has that functionality, so surely something with enough force to crush a car should have safety sensors.
(Didn't mean to be a parrot - simultaneous posts!!!)
I had no idea this was a self park scenario....I agree there should be some more sensors of some sort, crazy stuff. I wonder if the garage had you sign anything saying 'We are not liable for damage incurred while parking' or anything crazy like that.
I think it may be a little more interesting in a self-park situation but hope you don't have any issues and can get this resolved without much hassle.
This hurts, I am just praying there no frame damage and that its all superficial plug-and-play components.
From what I can see, I'll need in terms of major parts: both headlamps ~$2K/each, front-bumper ~$2.5K, hood ~$2k, radiator and some hoses $1.5K, undertray. Everything under the hood (engine bay) looks untouched from a visual inspection. Once the body shop gets the nose off we will see what's going on in there.
Thanks, I was really happy with how the visuals of the car came together. On a plus, if the car is deemed fixable, its time to get the SVR bumper to complete my final exterior mod.
SinF (01-18-2018)
#30
#31
#32
Picture of the car with lights on and a trail of pumped fluid leading to its new parking spot tells me it was driven there. Look at the ground in the 6th picture.
I think it is lucky they didn't also start it, but I'd double-check this unless you were the one extracting it from the lift. The floor looks like you lost all your coolant and maybe even some of the engine oil. If the engine is cold, you have a minute or so of thermal capacity before any danger of overheating.
#33
This is going to be an interesting case:
(1) The parking company will likely try to claim it was my fault for driving to far forward (passed the bump stop)
(2) I will claim it was a bad design and the garage should have some sort of warning system or fail-safe system. While I was trained how to park my car, but was never told what would happen if I mistakenly parked the car too forward (apparently a squashed car). There are sensors in the back to raise an alarm when the car is too far back, but apparently there are no sensors in the front to let you know when your car is too forward. I personally think this is a design flaw and can lead to property damage and personal injury.
My guess is this is the type of case that either one side assumes fault or something for the courts to handle. Searching for product litigators now in the Bay Area.
#34
That is a genuine drag and I hope it all works out in the end. Seems in SF you're damned if you do park inside or damned if you don't (vehicle break-ins at all time high).
But, having been in the insurance business for 35+ years now, it seems if you have comp/collision coverage your insurance company should take of the damage and they will in turn go after (subrogate) any recoveries from the garage operator or equipment manufacturer.... that's what they're set up to do.
#35
Yes, many condolences. Not a happy day. El Gato may be correct in that OP's insurance company may be the one to handle it ( at least in NY). Even if he was some how at fault his insurance will most typically cover it and visciously pursue compensation.
P.S. Can't wait for driverless cars!
#37
#38
#39
