Front Differential Fluid Change DIY
Hi Group...
As I mentioned in my previous thread on the Rear Differential DIY I took some photos and documented the Front Diff process, and put them in my DIY template. I have attached the Front Diff process here.
These are created in the spirit of helping others. If you have a better way of doing it, knock yourself out...this is simply what worked for me.
DC
DC
The following 3 users liked this post by Therock88:
DC
Panthro (03-31-2020)
Hi There....
Yes, likely at some point in the near future, and will similarly document and share. I ordered VAP Lowering Springs, but they are not in stock. When they come in (hopefully next week), I will be replacing the Coil Springs....So that will likely be my next DIY.
So far, I have done the following to the car in addition to the differential fluids: (All since November
Racechip RS Install
Aluminum Pedals
Created LED Growler Front Badge
Installed Yellow Wolf Intake System
Installed Larger Paddle Shifters
Installed 15MM Spacers
Installed Rear Wing/Lip
Installed Rear Spoiler disable switch
Disabled Auto Star/Stop
Installed Front Wheel Arch extensions
Installed Battery Quick Disconnect for rebooting
Applied Ceramic Coating to the car
Had the front and sides wrapped with Xpel
And a few other minor mods I am probably forgetting
Will document when I get time...
Take care,
DC
Racechip RS Install
Aluminum Pedals
Take care,
DC
watson6505
11-28-2019 12:03 PM
ANIMAL JAGUAR
Diesel variants - All models
11-14-2019 03:06 AM
sweatyfox
01-19-2017 01:10 PM
