Front tyre rubbing on the inside
Hi guys!
So I just bought a used F Type R from the dealership here in Qatar... Would've loved to buy a new one, but at $150k, and at the rate they depreciate it made no sense.
After a week's delay with the Jaguar inspection, I picked up the car, and I noticed that when I lean towards the right while driving at around 80km/ph or higher one of the wheels scrapes against something. It only happens when I turn the steering wheel to the right, otherwise it's perfectly fine.
I took it in today and went for a test drive, and the guy felt and heard the same things I did, but after lifting the car we couldn't spot any signs as to what was wrong with it... I was wondering if any of you guys had the same issue or had an idea as to what it could be?
Thanks in advance!
Thanks in advance!
Hadi Darvishi (05-10-2016)
Haha I knew I should've taken some pictures!
I'm taking it in next week or the week after, so I'll definitely ask them to take some pictures, especially if they find the problem for other people's reference.
Could be the inner fender well, but the issue is that the problem only pops up when on the move and over a certain speed, so when we inspected it as it was stationary it didn't seem like anything was touching it... even the technician was confused by it... he told me to take it to Jaguar's main branch for a closer look
If one fender well liner is missing a fastener or two, you might only hear it when that corner is compressed more by cornering at higher speeds. You wouldn't necessarily see anything obvious without inspecting all the fasteners and ensuring it's mounted in the proper position.
The fact that you're only hearing it on one front corner and when turning at higher speeds leads me to suspect something like that. At any rate, it should be a very simple fix.
I can't seem to pinpoint the sound exactly, but it feels more of a rubbery kind of thing... and I'm still not sure which side it's coming from, but it feels like it more from the right side...
The other thing is it isn't on a full turn or anything, it's just slight rights somehow... when I park it and turn the wheel left and right, absolutely nothing happens
I have read on another F-type forum that someone (including myself) have experienced a high pitch noise when driving above certain speeds. One of them put out a video where you can hear the sound:
https://drive.google.com/file/d/0B8c...JBSE1QU28/view
This guy experience it at "motorway speeds" (probabely a bit over), and I experience the exact same noise at speeds above ~ 140 mph (German autobahn).
Some suggests it might be a loose retaining clip somewhere in the instrument cluster or the interior light trim or the interior Mirror - that cause it to vibrate horribly at higher speed.
Just a suggestion....?
Alli Quinninho
12-22-2020 03:00 AM
