Front Washer Bottle Location
anyone kow where the front screenwash bottle is located and where piping from rer bottle runs.
Had car parked on a fairly steep slope today and there was a puddle under drivers side wheel. Warning on dashboard for low washer fluid which was just refilled on saturday.
So I am suspecting a leak somewhere
"The plastic, molded reservoir is located in the right (front) wheel arch,
behind the liner. It is secured to the body and front panel with bolts.
A boss on the reservoir locates into a bracket mounted off the A-pillar
casting and provides additional support.
The reservoir has 2 recessed holes in the side, which provide location
for the windshield and headlamp washer pumps. The pumps are push
fitted into grommets, which seal the pumps in their locations. The
windshield washer fluid hose is integrated into the harness and so
follow it's routing. The headlamp washer hose, from the reservoir, is
routed over the wheel arch and across the body between the
headlamps.
A hole with a grommet in the side of the reservoir provides the
location for the fluid level sensor."
See section 501-16 from this 480MB document which OzXFR posted. It's specific to the V6, though presumably the V8 is the same or similar.
https://www.dropbox.com/s/t2hfjv7bas...anual.pdf?dl=0
headlamps.
4x4uk (04-18-2018)
kfisher1031
04-20-2018 11:33 AM
