Can anyone advise the part number for the front left and front right spoiler for a 2015 F Type R (AWD).
My car being the AWD R has all the colour coded extended side sills etc and I am looking for replacement for the front spoiler sections as pictured below (colour coded) to match my Polaris white car.
Those parts come in 3 variants: Gloss Black, Satin Black and Primer (ready for painting).
You'll need to get them painted yourself.
Here are the part numbers for the primered pieces.
Right: T2R3559LML
Left: T2R3560LML
Right: T2R3559LML
Left: T2R3560LML
Thanks for above. You’ve helped me do the correct search and find the correct ones. The numbers you listed above are the primer version of the standard shape splitter that goes on alL models (see red car pic below for shape difference). The version (shape) I’m looking for is the kit that is standard across the R AWD model, which you lead me to find the correct code (as per below).
T2R16329LML and T2R16328LML
Thanks v much
Standard shape splitter Splitter shape standard on r AWD
I actually like the look of the bigger side splitters. Can’t believe how much more expensive the primed ones are vs already painted satin or gloss black.
I just replaced the three lower chin spoiler pieces and the front lower deflector. Not to difficult of a job with one side jacked up. Also got a chance to remove a ton of leaves and dirt from between the radiator/coolers. Cost was about 300 bucks.
