fuel injectors
Received 2,629 Likes
If you don't have a need for additional flow, there's not any reason to change them. If clogging is a problem, going to larger injectors with (presumed) larger internal passageways, it's still a no-go because it would mean reducing the injector on-time, or lowering fuel pressure. The former isn't possible with an OEM ECU, and the latter probably isn't possible if the OEM pressure regulator isn't adjustable.
