Fuel type options
Fuel type options
I ran my 2014 and 2015 f type V8 and R using Shell V Power (91 octane, no ethanol content). The only other option in my city with a higher octane rating is Mohawk 94 which has ethanol in it (5 to 10%, I cant remember). Which fuel option is better (I have a new R coming and want to keep it a long time, so I want to use the best fuel for long engine life, and have the best performance as well). I have a bad feeling about ethanol; is that misplaced?
Received 2,266 Likes
Yes it's misplaced, but never let facts get in the way of good old fashioned myth and rumour.
There's probably no point in using fuel higher than 91 AKI octane anyway- your car achieves full rated performance with it.
Even if fuel system is hardened against otherwise corrosive ethanol, it still absorbs water and forms residues that can plug filters, fuel regulators, injectors, and pumps. Ethanol also can etch aluminum and magnesium.
These are long-term concerns, this damage is very gradual and you won't see it until much later in the car's life.
New cars can better withstand some ethanol, but they are not completely impervious to it. There was a study done in 2012 that showed that with E15 (more ethanol) substantial segment of all modern engines showed damage after 500 hours.
I never use ethanol fuel. We have the option of a non ethanol 98 octane fuel here which is what I use, but I seem to recall a discussion where it was pointed out that we use different octane measurements. I think we use RON and you use and average of RON and MON which comes out at a lower number than RON for the same fuel
Cars since the early '70s have sealed gas tank that do not allow free exchange of air. That's the purpose of the EVAP system. Keeps vapours in, air out.
I've previously post pictures of my elderly Corvette's gas tank that's had nothing but E10 since the '90s. Zero corrosion or water contamination.
SinF (03-20-2016)
It is not available in "civilization" here.
Bear in mind that some members have regular access to
premium fuel without ethanol. I am one of them, and that
is what I "choose" to use. If I am caught short due to
bad planning on my own part, I will fill up with some
other brand that one time.
Jaguar (and good on them) does not require such fuel, unlike some other high end marques.
No one said park your car. I said use the best you have
available. For some, that means fuel without ethanol.
You can build a coffee table out of pine and stain it
to look just like cherry. Or, you can build it out of
cherry and have a hard time staining it, but it *is*
cherry.
Yes, if non-ethanol fuel was available, short of paying someone to truck it in, I would use it.
However, as I understand it, the biggest problem with it is sitting in the tank, and rest of the fuel system w/o moving. Thus, if it's burned quickly and constantly circulating, it's less of an issue.
On my mowers, leaf blowers, generators, etc., and anything that sits for a long period of time, I use an additive that neutralizes the effects of ethanol.
As others have said, Ethanol free gasoline here is about as available as unicorns. The longest that I've run a car with 10% Ethanol is 18 years and 235k. Never a fuel system problem. My yard equipment, including my over 20 year old snowblower always start on the first or second pull though I do use Sta-bil when I put them away for the season. No fuel problems there either.
There is a bill in Congress (or maybe it has already passed) to increase the Ethanol content to 15%. This is a bad idea and because cars are not made for it will likely cause issues (in addition to raising corn prices).
As for Top Tier, it is a marketing thing but it is based on some fact. Top Tier gas has more detergent than the EPA requires. This sounds like a good thing to me, but since I've always used Costco gas I've no experience using something other than Top Tier, at least not regularly.
