The MY is indicated by digit 10 of the VIN - I think P is for MY23, not sure if they use Q (they don't use I or O) so maybe R for MY24 and S for MY25. Anyone know for sure?
For all those interested, the e-diff and suspension codes were most likely caused by a flux in voltage from the car battery. This was dealt with at the dealer along with the O2 sensors for the check engine light. Problems solved 😃
Hi all, I've got a '21 F Type R and experienced the same problem recently. Previously, when I took out fuse 15, things were fine for a while. Then one fine day amber engine warning light comes on, followed by red warning light and reduced performance message on the dash. No special modes available. So I'd put the fuse back in and after some time driving, it would correct itself. I finally decided that I'd leave the fuse in. However recently (with the fuse in for weeks now), I'd still get the warning lights and reduced performance. Took it in to my dealer and they determined it's a faulty throttle pedal position sensor. Am getting it replaced will see if that cures it!
interesting. I don’t think that was related to fuse 15. As soon as I got the car back from the dealer I took it back out so I’ll let you know if I get any other error messages.
I never got any reduced performance with the check engine light as it was an O2 sensor.
