Which fuse in luggage fuse box turns off when ignition is turned off?
Hi All,
I am hardwiring a dashcam in my 2017 F-type Coupe and I am getting the power from the luggage compartment fuse box.
I am having a hard time figuring out which fuse to tap into, as all the fuses seem to be alive when the ignition is turned off. Can someone please recommend a fuse that I can use? I hope there is at least one! Otherwise all my planning for the wiring will go to waste and I will have to re-do everything...
The easiest way to find out which one goes dead would be to use an inexpensive (or expensive one if you already have it) multi-meter to check for voltage.
