FYI: NEW Oem carbon fiber diffuser on EBAY
FYI: NEW OEM carbon fiber diffuser on EBAY
This part is a unicorn. I was looking for a new OEM carbon fiber diffuser for a long time; they don't exist. There is one left on EBAY. The seller had 2... Yes, it's expensive, but still below retail. But if you wanted to keep your car all done with the same carbon fiber weave and OEM, this might be your last chance. I bought one, and it arrived quick, and its 100% legit. He had 2...it's in Europe, 'm in USA arrived FedEx, perfectly.
mine is a 2016 S. This has the same lights as mine,( thin white small) so I was good. . He also has these for sale if you have rhe older models with the larger red/while light like Koshi diffusers fit.
That's the same part number I have and the lights did NOT swap. There are at least two differing sets of reverse pods for NA last I looked. Eventually, I had to get replacements for the V8 to match the brackets on the CF diffuser (T2R19007 and T2R19009).
Not looking for another (obviously) just curious as to often these differ.
https://www.ebay.com/itm/124126275534
jaguar is doing the install next week. I will know then. Are you saying you had a S model v6 fwd 2016 and it's needed v8 replacement pods? The diffuser didn't come with any brackets. I was assuming they would juat take any parts off the diffuser I had on now and swap. Buy I'm clueless, hence why I'm having Jaguar do this.
In my case, I was told they would swap but the brackets epoxied to the back of the CF diffuser wouldn't accept the assemblies clean. I ended up using some nylon bushings and zip ties to attach them snug while hashing out what happened with the dealership and JLR. Needed to be able to drive it until the other parts arrived (a week or two) and didn't wanna put the old one back on.
The brackets didn't align and weren't flush. No swap.
I have a base V6. I mentioned the S because I read wrong and thought you had already had the light assemblies successfully swapped.
The brackets didn't align and we're flush. No swap.
I know some of the older models had the biger light red/white...but that isn't case. Is rhis a euro/ usa different spec situation? Why woukd jag sell a v6 diffuser that needed v8 brackets? 😆
what year was your jag?
I'm still confused. If the part is for the V6 model and it's stated by the jag dealer as fitting a v6 model. But you said your v6 lights didn't fit rhr v6 CF diffuser, and needed v8 brackets?
It's entirely possible that it's a model/year thing, but the details are scarce on this part as even the dealer couldn't tell me if new pods were even supposed to be included.
Sorry I've brought all the confusion. I was still trying to understand everyone else's experience with it. Fortunately, it looks really nice once you get it on there.
I was confused too, but the brackets (the ones permanently attached to the diffuser when constructed) did not align with the lights in the 2016 base V6 diffuser (flat black). I needed the part numbers I listed earlier.
For the S with no additional aero, the bumper should not have to come off (I'm not sure about the Bristish Design Editon rear aero).
The removal process is VERY simple and didn't require me to even jack the car. From what I remember, there were less than 10 screws (2 for the exhaust "panel") and only the harnesses for the backup pods and 4 rear parking sensors. The diffuser itself wasn't attached with any adhesive, just a few tabs that released easily.
It was a 45 min job for me and that was blind.
Mine was a whole kit so the only hassle I had was the missing cover for the transport eye. Since it was NOS the missing piece was a write-off and I fabricated something. I found the installation as straightforward as you did, although I did roll the rear onto ramps for a little more working room.
zochmenos (10-23-2022)
Yep, a total cluster F****. Definitely need new lights which aren't cheap. And jag is still not 100% sure which ones. They are like $500 a piece.
The parts you need would be the pods from the NA V8 (T2R19007 and T2R19009).
As far as I can tell you ought to be able to install them without taking the diffuser back off. It'll be a bit tight I'm sure but it's not enclosed by a trim panel or anything.
The other option (which I ran while waiting for JLR to sort out this same issue) is to use some nylon bushings and zip ties with the existing pods. They tighten up rather well and anything that would dislodge them would also likely break the brackets on the diffuser itself. It isn't a permanent fix as zip ties will deteriorate more quickly than the appropriate mounting method but it will work for a good long while.
