GAH I locked my keys in my car. Dead battery.
My keys I locked in the car are the only ones that have a manual key inside. Story time:
My battery died due to that stupid ODB bug after I went to a mechanic for an oil change. I called AAA to get my battery jumped, and the manual key wasn’t working.. the guy tried to get the door open through my window, and shattered the window.
That window is now replaced, but it took four days and the guy didn’t jump the battery because he thought I should wait until the car is drivable (not shattered window). In those four days, apparently the battery completely died - I had it jumped earlier today, drove for an hour, but it doesn’t hold charge.
I just got home and found a company to come replace my battery, but realized my keys fell out of my pocket. I’m intensely frustrated and hating myself.. what can I do here? Do I call AAA again and hope they don’t shatter the window??
How were you able to lock the car with the keys inside? My car won't lock via keyless if the fob is still in the car.
It also won't lock if the fob is more than a few inches from the door handle (e.g. I'm standing with my right leg near the handle but the fob is in the left pocket) but that's a different story.
The only options the OP has are to risk another window break, or wait until the dealer can secure a replacement key. I have found that failure to successfully use the emergency key stems from not fully inserting it in the hole. It should be slid in deeper than one would expect.
The following 3 users liked this post by Unhingd:
Even with another fob, there’s no way to get juice to the car to open the rear hatch or to use the fob to open the door to access the bonnet latch.
oh...I believe OP already mentioned that the fob locked in the car was the only one with the emergency key.
Removing a 3/8”x3/8” section of insulation should be sufficient, and easy enough to patch afterwards with a couple winds of red electrical tape.
Thank you for the pointer, amazing to know! I didn't see this until today, yesterday I had a locksmith come out, he said he could get in via the window without a problem. I reminded him of what happened last week, he said don't worry, and he got the door open without a broken window in under 20 seconds. Obviously way more skilled than the other guy. Crisis averted!!
My guess though is that there is no bare cable inside the box, but worth a look by the next person who removes that wheel well lining.
JacksonvilleJag (10-12-2020)
Ok so this post got me curious. I bought my car used and never tried the emergency keys on either fob that came with the car..
Just went down to the garage to try both. Neither appears to work? I did not want to snap the key off by forcing it. I have a couple of questions.
Both fobs work fine.
1. How far in to the key hole do they keys need to be inserted?
2. How difficult is it to get new emergency keys?
3. Any idea how much these keys cost to replace?
Be careful not to twist too hard, I had to get a second key for a fob from the dealer. They are matched to the VIN.
My lock lubricant of choice is Lock-Ease, a graphite lock lubricant. It is available in drip bottles or aerosol. There are other 'dry' lubricants too.
You MAY need to use a penetrating oil to free the cylinder up. PB Blaster or Kroil are good, but lubricate the lock cylinder properly afterwards after you finish.
Graphite lubes do not attract dirt, the drip stuff has a liquid carrier that evaporates.
I lubricate the locks once a year, yes the emergency key is not the easiest thing to turn but they DO work.
Don't forget the manual key-hole in the trailing edge of the driver's door (near the door latch).
