getting an odd sound with throttle input
Car has 6500 miles on it. I can't say that I recall hearing any such noise before maybe a month ago, but now there is a bit of high pitched whining (do not confuse for a supercharger sound) only when under throttle input. This occurs even with light feathering of the throttle when coasting at speed on the highway. The noise rapidly tapers off when the throttle is released. I haven't noticed any change in performance of the car whatsoever. The noise is a bit more pronounced when the engine is cold, but it persists for my 15 mile drive to work.
Any ideas what this might be?
SITUATION:
A 'humming' noise may be evident from the engine when the engine is idling.
CAUSE:
This may be caused by dust and/or water ingress to the accessory drive belt idler pulley bearing.
ACTION:
Should a customer express this concern, follow the Service Instruction below.
CAUSE:
ACTION:
Originally Posted by Unhingd
My noise doesn't sound like a humming..more like a loose fan belt (but none of the belts are loose). Noise is not coming from the SC snout. Used a stethoscope to confirm that.
I too have been getting this for quite some time On my XE (see XE build at bottom) Same V6 engine as F-Type. Cicadas is what describes it best. Is it indeed the belt? It's apparent with acceleration starting at around 3K RPM, It does not change in pitch with revs, just intensity. I'd love to find out what this is. Here is a link to a couple of accelerations..high pitched cicada sound
https://vimeo.com/192842918
CRS
CRS
CRS
CRS
Hard to isolate the frequency with cam audio. It's at the high end of the spectrum. Sometimes I wonder if it's the belt tensioner bouncing around on the belt? I had a blackvue dash cam on my other car....I think I like the Street Guardian much better. great video quality and low profile:-)
