Give Me Some Air!
Received 2,263 Likes
I live in a colder climate than Oslo. Cars stored for 4-6 months is very common here. Permanent tire flat spotting is unheard of.
Tire Care and Maintenance | How Do I Care For My Tires? | Michelin US
Not good enough?
From the Michelin website:"If tires are on a vehicle parked for a long period, the weight of the vehicle needs to be taken off the tires by jacking it up or removing the tires. Failure to do this may cause irreversible damage".
Not good enough?
Not good enough?
We're also told by many electronic appliance manufacturers to unplug them when we leave our homes because they "could" be a fire hazard.
#28
I think increasing the tire pressure some 20%+ (to ~ 50+ psi at storage temperature) will reduce the risc of permanently damaging the tires good enough for me not to worry.
However if you store the car with normal pressure at ~ 70 F, and the temperature drops to ~ 30 F, your actuall tire storage pressure will be close to 30 psi. And that would have made me worried.
#30
Ox. makes up close to 21% of air (varies according to sources) and when replaced by the larger molecules of nitro, your tire losses air more slowly... and yes, this is the case with my vehicles and heavy equipment. Typically we do not need to add any air during the year on vehicles with a proper nitro. fill. We have checked and verified as comparison.
Ox. has moisture and nitro does not... its the moisture that expands as its heated, thus we have nascar and formula one using nitro.. at least the last time I checked. Temperature does have some affect on tire pressure, but a bit less on nitro fill.. its the overall issue of my pressure remaining constant that works for me.
Mine are filled free of charge, just to deal with the argument relative to cost and I have a couple of 'air pigs' that are full of nitro to top up if I need to.. but have found the annual change over has been the only time I've needed to add a pound or two after the tires sit all season. The nitro source needs to be of a high percent to be effective.
Lawrence.
#31
#32
"2. If the vehicle cannot be put on blocks, the following is required:
• Tire pressure should be increased 25% from the inflation required for the loaded vehicle (ensure that the rim manufacturers
inflation capacity is not exceeded)
• Unload the vehicle so that the minimum weight is placed on the tires.
• The storage surface must be firm, clean, well-drained and reasonably level. Do not store tires in contact with black asphalt or
other heat absorbent surfaces and do not expose the tires to highly reflective surfaces such as sand or snow.
• The vehicle should be moved at least every three months to prevent flat spotting and ozone cracking at the tire sidewall flex point."
Unlike technical info drafted by federal agencies, most industry publications are crafted by experts in their respective fields rather than lawyers and politicians. This was written by tire experts, not attorneys.
#33
But if the theory was true and only the oxygen leaked out, the contents of the tire would soon be 100% nitrogen and the leakage rate would decrease accordingly. That doesn't happen in real life.
Static cold tires pressures are formulated by the OEM using good old fashioned flaw-laden air. If the theory was true that 'nitrogen expands less', this would mean that the tires would be under inflated on the highway.
The reasons that aircraft and some racing cars use nitrogen are valid, but don't apply to street driven cars.
#34
1) make a device that slowly moves the car fore and aft the distance equal to the tire's circumference
2) there's plenty of unemployed champagne riddlers in France since the business is now mostly mechanized. Retrain them to become tire riddlers.
#35
Unlikely for that reason alone. From the Tire Industry Association Best Management Practices Guide for Tire Storage:
Discussing a subject with you is a never-ending, moving target, and you often quote out of context. We're talking remote probabilities not worth worrying about. Now you cite another source citing many more issues than permanent flat-spotting, a term not specified in your latest citation.
At least this source is more credible, and it's not a bad idea to roll a vehicle a few inches every 3 months . . . or not, and there's a 99.99% chance you'd still be OK.
#36
#37
The difference in molecular size between oxygen and nitrogen is insignificant. Even if there was a difference, there's no inherent property of rubber that makes it a consistent filter for nitrogen vs. oxygen. The 'pores' in rubber are very inconsistant in size.
Oxygen contains no more moisture than nitrogen. Air might have some, depending on how well the compressor and lines are looked after. The volume of water in a typical tire is insignificant and has no effect on pressure until it vapourises. Because of the pressure inside the tire, the temperature at which water vapourises is well beyond anything seen on the street.
Anyway, each of us has our own way of maintaining our various vehicles.
Lawrence.
#38
You mentioned before that the effects would only be apparent on tires with a very high concentration of nitrogen as source.
How does your tire shop get rid of the air that's trapped inside during installation? If it's fill/bleed/refill/repeat it's very ineffective.
If they just add nitrogen on top of the trapped air, then the concentration of the resulting mix goes from 78% (plain 'air') to the mid 80s.
Hardly worth the effort.
#39
