Got my F-Type Wrapped
MM
madmax1911 (09-28-2020)
They should be good for a few years depending upon how much you use the car, weather conditions and if it is garages etc. I have been learning, totally self taught. Thoroughly clean the area with isoproalchol and use a reasonable pressure when applying the wrap
i had to redo a couple of areas where I did not get it right but once done wraps hold up well and they have been washed many times now. Also applied ceramic coat to parts and polish and they come up really well.
good luck and post some pics when your done will be interested to see the results
#28
Very nice on the self-wrap bits. I can do easier things like flat surfaces but would not trust myself to be effective on large panels. Since I was going for a color change, I went with the professionals. The shop said the hood in particular with the Inozetek brand wrap (low stretch) was a 4-person job, as it is a huge single piece to put down at once.
By the way, here is the door jamb - my car was Ultimate Black so this turned out to be a perfect transition with the plastic sill material, IMO.
madmax1911 (09-29-2020)
