Grille S badge removal?
Fenton (03-06-2016)
To amplify, it's the entire front nose piece that would need to come off. The "bumper" and "grill" can't be accessed from behind with it on the car.
You'd have to REALLY dislike that badge to go through all that trouble. While removing all the fasteners isn't all that hard, there's an awful lot of "fiddling" that has to be done to get all the seams at the hood and fender panels to line up properly when reinstalling.
Fenton (03-06-2016)
As long as you don't damage the honeycomb grill in doing so, which is plastic just like the badge. I have the base, which doesn't have one and can't examine it to see if it's possible to Dremel it off without damaging anything else.
BTW: Rather than cut it out with a dremel which will get rather messy and carries a high risk of damaging the honeycomb grille, might be safer to drill directly opposite the two screws from the front side (should be able to feel the screw heads by sticking a finger through the grille), with something like a 1/4" drill bit. Its all plastic and will drill quite easily, and once you reach the screw point, then drill three or four holes around each screw tip with an 1/8" or smaller drill bit and this should remove enough plastic that the back mounting plate should just fall out.
As Foosh mentioned, it is quite an undertaking to free the grille, although the only tools you really need are Torx 20 and 30 bits, along with 8 and 10mm sockets. I did it yesterday to install a new surround. It wouldn't have been too bad with a lift, though. And it helps to pay attention to how the various trim pieces fit, it will make reassembly easier. Front wheels and fender inserts definitely have to come off....
Pretty certain that is part of the backing to the badge, and will separate from the grille when the screws are removed or cut out with a dremel as the case may be.
GRILLE & COMPONENTS for 2015 Jaguar F-Type
domino_z (03-10-2016)
that's so weird, unless they changed the grille part for my16?
i run my fingers around it and can't feel any edge where the base plate is a separate piece
does anyone have actual pics of the grille with badge removed?
just google image'd the part number from your link and you're right
ill double check for my16 part number if different
![](http://www.jaguar-shop.com/WebRoot/Store22/Shops/62413452/537D/FF75/F56E/2097/C5BC/C0A8/2AB9/9175/IMG_4415.JPG)
has anyone thought about taking off front undertray trim to reach up behind the badge? or even use an S bend screwdriver to go in through the front
![](https://cimg8.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1024x768/20141214_213731182_i_os_28b47320b8a32db5272aba39d13e410ce12f73c7_c6717c53f96b9151aa3610dcf4a315e9f509d697.jpg)
Alex Dougan (05-10-2020)
