OEM? Those create enough dust to embarrass a BMW owner. It only takes a couple of days before I've forgotten what color my rims started out. I'll be looking elsewhere.
I've only used Porterfields in the LeMONs car, and that's all we've used there. No back-to-back comparison available. I've used Hawk on the track in my 9-2x, but that's the only other car I've tracked. No help from me here.
EBC started showing up when I was still racing motorcycles but didn't take long to establish a decent reputation with the GreenStuff pads. I have vague recollection of a contingency program, and that was always welcome. I was using Ferodo and Performance Friction though because of the bikes I had. No help from me here either.
Initial reports on the YellowStuff are encouraging, so I'm leaning that way, but welcome direct reports on anything.
Brake dust isn’t an issue for me. The wheels are cQuartzed and easy to clean. I’m far more interested in brake fade, stopping power, rotor wear characteristics. Noise for me not an issue as long as it’s not squealing.
I've got my rims coated too, but OEM dust is crazy. I'm assuming that both Porterfield and EBC should be at least as fade-resistant as OEM. Rotor wear is something we'd need to research on something comparable, since I don't think we're going to see any long term reports on aftermarket F-Type brake components for some time yet.
All that said, if OEM were best, dust notwithstanding, I'd use them.
I've had the Porterfield R4S pads on for about 3,000 miles now, with after-market drilled and slotted rotors, and I can't feel or see any signs of rotor wear at all, zero outer lips on both front and rear rotors. I checked them again yesterday.
So it looks like the Porterfield R4S pads don't chew through rotors at all.
That said I'm not a heavy braker.
My stock setup is showing a noticeable lip on the front and rear rotors at 24K miles. Most of my miles are commuting, but when I want to slow down I'll use the brakes, and not always gently. I'm sure it's a combination of the pad, the rotor, the weight, and the speed that can be achieved that are contributing to rotor wear, but as long as it's not excessive, I don't mind. Brakes are a wear item. I'm more concerned about having to replace my clutch more often than my brakes. That's just not right.
I've never had ABS engage in those circumstances, but like to know how the car behaves when I throw out the anchor. Really well, in case you're wondering ;^)
Anyone have any comments regarding the Porterfield R4-S pads?
Like Iron Mike, mine still in box awaiting new rotors!
However, I put them on my M3 6 months ago, and am very impressed - at least for street use. Brake dust is 50-70% reduced, pedal feel is linear and firm, brake power consistent with stock and rotor wear is very low. There was a touch less (10%?) initial bite, but I got used to that quickly. Hoping for similar experience on F type, as I think the brakes will be less "grabby" at low speeds/parking situations.
Losing a little bit of initial bite would not be a bad thing on this car. The EBC pads are substantially more expensive than the Porterfields. I was wondering if there was a corresponding performance advantage. Want to have a new set of pads waiting for the Wortecs as well.
My comments were similar to those of Chawumba. Overall the dusting is almost completely gone and initial bite is more easily modulated. After 2k miles I would say the braking performance in street driving is equal to or better than that of the stock pads.
I feel the same way. Creeping along in traffic or in town I do find the stock brakes to be a bit too touchy.
I'll probably go with the Porterfields too. I just need to get fully caffeinated before making any important decisions.
Wortec is on track for it's two week production estimat. The rotors are machined and the bells are turned. The bells need machining and all parts need coatings.
We will get an update again mid-next week.
Some more pictures from this week.....
