Group buy: 2pc wortec rotors for steel super brakes on f-type
#62
Paul
Just sent me this, a customer who owned a Lambo with ceramics but wanted to convert to steel due to track days, Wortec were able to do him a full conversion with hardly any weight penalty:
So it looks very good for us. Considering our stock steel disc are so damn heavy, the front are 18kg / 38lbs and those who go with the suncuts will probably be under 10kg on the front, practically half the weight.
zmoothg (03-02-2018)
#64
That is the whole point of this, throw out the 1PC dustbin style rotors in exchange for some nice 2PC sportier looking rotors that save you a load of weight whilst at it, similar weight savings to ceramics but costing only around $2500 for an entire set of disc.
#65
#66
So here's the official group buy list:
1. Gibbo205 - Round disc, drilled only - UK
2. Unhingd - Standard Suncut disc, slotted & drilled - 20904
3. F-Type-Type - ??? - Denmark?
4. zmoothg - Round disc, slotted & drilled - 94103
5.
Feel free to pile on if you are committed.
vettegood, are you in? Looks like the cost will be around £2000 for the set delivered to the USA. Less for the UK and EU. Conversion is $1.38 to the £.
F-Type-Type, which disc configuration do you want?
5.
#67
I'm still trying to justify this, but am leaning more towards joining.
My preference has no weight without a commitment, but in order:
slotted only, standard suncut
slotted and drilled, standard suncut
Unless the cooling benefits are substantial, the aggressive suncut look is a little off-putting. It reminds me of something some squid would put on his Ninja.
#68
5. IronMike - Drilled in the Slots, Round or Std. Suncut (undecided) - 92627
6.
7.
6.
7.
#69
Did I read correctly that Paul indicated the Suncut are not cast?
I think these are a great option. Had never seen the holes in the slots before this pic was posted, but makes perfect sense for keeping the heat away from the holes, and also helping to keep the holes clear of dust.
The Suncut, even in the standard form, may be a tad too aggressive for my taste.
#71
#72
My understanding is that all varieties would begin from the same disc casting.
Here's what we have to date:
2. Unhingd - Standard Suncut disc, drilled slots - 20904
4. zmoothg - Standard Suncut disc, drilled slots- 94103
5. IronMike - Round or Std. Suncut (undecided), drilled slots - 92627
6.
7.
6.
7.
#73
6. Chawumba - Round Disc, drilled only, or 2nd choice drilled/slots - 90803
7.
7.
#74
Received 3,216 Likes
I fitted Porterfield pads with drilled and slotted rotors over six months ago and so far there is very little pad wear. Admittedly I rarely drive it hard with heavy braking (the boys in blue are unforgiving and the speed cameras are everywhere around here) and I'm a light braker 99% of the time (look up COAST).
#75
7. Vettegood - Round Disc.. Drilled and Slotted - 85086 ( just like IronMikes picture 6 posts above )
#76
Perhaps worth inquiring as to price of extra discs 'while you're at it'? You may have more leverage as a group now than individually 3/4 years from now when new discs are needed. Seems to me that a good part of the cost of 2 part rotors is actually the hat, which is certainly a custom part, so that's an investment that only works if its used with multiple discs which you will certainly need down the line.
Of course if y'all were able to standardize on one design, the order becomes x hats and y disks, all the same. Personally, I find fronts wear out way faster than rears, so if *I* was getting spares, they'd be fronts.
Just a $0.02
Just a $0.02
#77
Just a $0.02
Just a $0.02
The main reason is the "anti-dive" built into the braking system which applies the rears earlier and harder than the fronts, and the secondary reason is the way the parking brake operates.
Lots of reports on the XF and XJ forums on this, just a little early yet to report anything conclusive on the F-Type.
#78
#79
2. Unhingd - Standard Suncut disc, drilled slots - US 20904
3. F-Type-Type - Round disc, drilled slots - Denmark 2820
4. zmoothg - Standard Suncut disc, drilled slots- US 94103
5. IronMike - Round or Std. Suncut (undecided), drilled slots - US 92627
6. Chawumba - Round Disc, drilled only (or 2nd choice drilled slots) - US 90803
Given your 1st choice is that of the OP, those will definitely be in the lineup.
7. Vettegood - Round Disc, Drilled Slots - US 85086
8.
Based on the above, it looks like we need to limit this group buy to the following 3 options:
1. Round disc, drilled only (2)
2. Round disc, drilled slots (2 or 3)
3. Standard suncut disc, drilled slots (2 or 3)
Can everyone live with that offering?
I will check on the cost of the replacement discs. I suspect they are a fraction of the cost of the 'hat'.
#80
