Group buy: 2pc wortec rotors for steel super brakes on f-type
#141
Just a heads up - export orders from the UK to the USA should not be charged UK VAT (20%) that UK residents must pay. Usually, prices in the UK are quoted with the VAT already included, so a deduction may be in order depending. Gibbo205 excepted, so US buyers should get theirs for 20% less than Gibbo205 (before shipping)...
#142
But of course it would be good practice to double check.
#143
+1. I seemed to remember that original quote, but as you note, worth double checking. Thanks so much for getting us pointed in this direction.
#144
Unfortunately Jaguar do not make it particular easy as they don't really offer any performance modifications for our cars, like companies like Ford, BMW do for their customers.
As such we need to source our own and as British seem to use lead for aluminium our F-types are quite porky cars for what they are.
If I was in charge of SVO, I would make a production light weight coupe in limited numbers like they did with Project 7 and 8, still aimed at the road but with a more track orientation by using stickier tyres and removing even more weight.
For me ultimate F Type would be:
SVR with 600PS from factory (Project 8 tune)
- Ceramics or 2PC regulars
- Carbon roof, carbon pack
- Lighter carbon bucket seats but still nice comfortable ones with regular seat belt and ditch the electric adjustment and controls.
- Remove the motorised heater vents, infact just ditch the central vents completely.
- More basic radio option
- Fixed carbon spoiler, with manual adjustment.
- Lighter 20" forged wheels, possible to get down to around 10kg
- Michelin cup 2 tyres
- Thinner glass for rear screen
- Less leather, more suede / alcantara based interior
- Thinner carpets
- Less sound deadening
Then of course RWD or AWD, I'd personally want AWD as I'd want to drive it daily but if they did the above, maybe even made AWD and RWD versions I suspect they could get a RWD down to 1500-1550kg and an AWD to around 1600kg.
So your talking Porsche 911 Turbo weight, similar power but way better sounding and way prettier, would be truly epic fast cars.
Of course we could within reason modify our own cars to reduce weight with seats, exhaust, wheels and brakes being the easy areas to cut out around 100kg from our cars.
FR500GT (03-09-2018)
#145
Clearly Alcon do make a kit that fits our cars:
https://www.invictusgamesracing.com/...he-cars-jaguar
When I emailed them they said no however.![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
Still a 1450kg F-Type, gotta be a lot of fun that!
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
#146
Latest communication from Wortec:
Paul@Wortec
thank you for the list.
We are working on the designs and the castings are being produced.........we will make one set and test fit to the car in the UK....... (Gibbo205)
Once we are happy I will then sort out deposits for the production run.....
I will try and keep you updated as we go with pictures etc.
#147
Still a 1450kg F-Type, gotta be a lot of fun that!![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
#148
#149
That's my thinking. They list kits for other cars that have 380mm fronts, so they have a caliper of the right size/curvature. The rear uses an unusual (for an F-Type size) so that lends credence to the custom aspect.
#150
Any idea how long we may be looking at before they are ready for production?
Weeks or Months?
#151
#152
#153
#154
Hub studs, and wheel nuts for reducing unsprung weight. Titanium will be less strong but is less prone to fatigue and corrosion. Not sure if it is worth it when no-one has ever done this but I believe that Jaguar used the same studs for the XK and perhaps some other models, so i was hoping that there could be an off the shelf solution.
#155
I just did some calculations on the weight of the steel studs and estimate them to be about 55 gr (1.78 ounces) each, i.e. 1.1 kg (2.2lbs) for all four wheels. From Philly single's post I know that titanium nuts save 1.75 lbs in total. On second though a total weight saving of 4 lbs is not significant enough to justify the costs and effort, even if they ar off the shelf.
#156
#157
Thanks for explsining the strenght of the variois grades steel and titanium. Still fear that the total weight savings are not justified and could be better spend on e.g. a carbon hood. BTW I have oredered this 1.9kg supposively plug and play lightweight battery from LiteBlox: https://en.liteblox.de/?product=lite...redirect=en_US
will let you all know how that works out. A 4lbs battery is defenitly a substantial weight saver :-)
#158
I suspect there isn't much weight savings in the CF over aluminum hood.
The battery you selected is too small. The Jag battery has a 90Ah capacity and this one is only 17.5/52.5 (PB equiv.) Ah. I believe you will need to go with their larges battery (even that might not be adequate).
#159
Thanks for the feedback Unhinged! I was also surprised about the battery capacity that was recommended by LiteBlox but they were confident that the 19XX model will suffice. I tend to trust them since they haven nothing to gain recommending a too small battery (they will have more business with the lager model). There is a lengthy explanation on their website as to why the capacity of their battery cannot be compared 1:1 with conventional batteries. Never-the-less I will do one more check with their support, and keep you updated.
#160
