Group Buy: (4) 17mm hubcentric adapters/spacers
#261
#262
SanDiegoJAG (10-13-2016)
#264
#266
Received 3,209 Likes
#268
I have the 15mm spacers from the first batch that was made. The reason folks subsequently chose to ask for the 17mm spacers is that it reduces the amount (or eliminates the need ) of wheel stud grinding. With 15mm spacers and a Gyrodyne wheelset, I had to grind 3mm off the end of the wheel studs. Really a non-issue, since the thread doesn't even begin for the first 6-7mm of stud. With the 17mm spacers, folks had no grinding or about 1mm to grind depending on which wheels they had.
#269
I am unclear if the 17mm actually cover the studs because the spacer is now deeper than them or, is it a case of the wheels having inserts that can now accommodate the stud length remaining past the thicker spacer. I ask as I am looking to buy four 245/40 Savini wheels for winter needing rear spacers and they have no inset to accommodate any length of stud. Thanks for any thoughts
#270
AbyJag (10-19-2016)
#272
Burt Gummer (02-06-2017)
#276
#277
I lowered mine 1.5" with 15mm spacers. No problem with 295 tires, but 305 tires rub under compression. Ride height should not affect rubbing, as the car will have the same ride height when springs are fully compressed whether lowered or not.
Dremorg (02-08-2017)
#278
#279
#280
Well as you and I have identical colour schemes this is helpful thanks. I've had my 17mm spacers from is buy for a few months and have just not gotten around to putting them on because I need to spend the time grinding down the studs. In the interim I've been debating how I would like the new look. Now I know...it's pretty good!
Twhite (02-11-2017)
