Group Buy: (4) 17mm hubcentric adapters/spacers
#321
Correct, and the rear wheel is an 11 as opposed to 10.5.
#322
The SVR wears 305 rears but the offset is more positive (less negative) on the Maelstrom wheel, which results in the wheel actually moving slightly inward, which might allow for a slightly wider spacer. Next week, I will pull off my rears and get the exact offset.
#323
The following 2 users liked this post by Unhingd:
Burt Gummer (08-12-2018),
Dan's cat (05-09-2017)
#324
#325
#326
#328
#329
Jaggyx (08-12-2018)
#330
#332
Calling all new F-Type owners...
OK guys I just called Lenny down at Motorsport Tech, the guys who did the GB for the elder members (40 units) and we are going to do a round two.
The advantage now is the adapter will be at 17mm which now PREVENTS THE NEED TO DO ANY CUTTING OF YOUR STUD!
This is huge as it will save us time and money. These are now a true DYI without the needed in involvement of expensive wheel companies or machine shops. No grinding at home.
I was quoted $245 shipped for one set but was told that we would all get $50 off if we can get 10 or more people involved.
Delivery will be within a week!
Please express your interest here, in this post.
I will post before and after pictures so you can see the difference!
Want to thank VIC55 for his original post that offered his advice and pics from round one.
*These will fit a Coupe with the 63.4mm center bore, correct?
#333
Call Lenny - mention jag forum for discount
Motorsport Tech
280 S Rock Blvd, Ste 100
Reno, Nevada 89502
(775) 351-1000 - Voice
Motorsport Tech
Reno, Nevada 89502
#334
#335
Motorsport Tech
Reno, Nevada 89502
Motorsport Tech
Reno, Nevada 89502
#336
#337
Received 3,209 Likes
I have replaced two broken spacer studs now, and the replacement studs I bought from a local auto parts store (Repco) came with 22 mm open nuts.
Once I removed the broken stud I inserted the new stud, hammered it in just a little to get it to grip then simply pulled it in tight using the 22 mm nut, then removed the nut.
Of course it helps to have a workbench vice to do this!
#339
Just installed my 15MM spacers in the front. Is anyone experiencing a bit of force fitting the wheel onto the spacer hub? My wheels don't mount on the spacer hub without having to be pursueded by tightening the lugnuts.
Also, the rear factory studs need to be trimmed more than they do in the front with Tornado wheels. Tried to bolt up the rears as well and there was a very noticeable gap.
#340
