Group Buy: (4) 17mm hubcentric adapters/spacers
Old 08-20-2018, 09:03 PM
mlebofsky's Avatar
Originally Posted by zmoothg
The SVR wears 305 rears but the offset is more positive (less negative) on the Maelstrom wheel, which results in the wheel actually moving slightly inward, which might allow for a slightly wider spacer. Next week, I will pull off my rears and get the exact offset.
Did you have a chance to pull off the SVR wheels to see what spacers you can technically get away with?
  #342
Old 10-16-2018, 11:21 PM
Forrest Keith's Avatar
  #343
Old 10-16-2018, 11:25 PM
Originally Posted by Unhingd
Not to worry...they do. Nati and I are just reenacting the War of 1812.
And it's 92 ft-lb, by the way. lol
  #344
Old 02-26-2019, 02:17 PM
unccoda5's Avatar
Hi there! I am the guy who bought your Gyrodynes of Ebay! Did you go with the 17mm from motorsport tech? If so do you have any pics and are you happy with them? I am talking to them right now about getting a set. But for some reason they quoted me $285 instead of $245......
  #345
Old 02-26-2019, 02:57 PM
lizzardo's Avatar
That was the group buy price.
  #346
Old 02-26-2019, 07:05 PM
IronMike's Avatar
There may be as many a 100 F-Type owners who have purchased Spacers from Motorsport Tech thru this forum, and I don't know of anyone who has not been thrilled with the quality of the product and/or the fitment to our vehicles.
The size spacer you settle on will depend on what wheels and tires you ultimately settle on. I'm running 17mm spacers on the front with Jaguar wheels and factory sized 255/35 PS4S Michelin tires. On the back however, I'm running 10mm wider than factory 305/30's with 15mm spacers.
Most are running the same spacers front and rear, but this set-up works without problem and I really like the wider tires on the rear. Even though its only a few mm, they look like they're an inch wider, especially when spaced out flush with the top of the wheel arch...
Burt Gummer (02-08-2020)
  #347
Old 02-27-2019, 09:37 AM
unccoda5's Avatar
Iron Mike, I completely agree with you and I think the 305s do add a lot. Not to mention that slight bit of protection around the lip. I may just have to copy your set up when it's time to replace the rear tires! I'll be rolling on the stock gyrodynes for the time I have the car most likely.
  #348
Old 05-12-2019, 06:20 PM
Obi's Avatar
Obi
Obi is offline
Originally Posted by vettegood
Hello,
I have two brand new 17mm spacers in anodized black with mounting nuts included.
if anyone bought 15mm and wants a bit wider in the rear.
These are new from motorsports in Vegas never been used or mounted. 75.00 plus shipping
85086 zip
By any chance are these still available ?
  #349
Old 05-25-2019, 11:14 PM
Originally Posted by eshin
If anyone is interested, I have a set of 4 brand new spacers from the motorsports-tech buy. 17mm w/ studs and lugs.
Looking for $200 plus shippping, zip code is 90013.
I am interested but new to forum and can't private message. How do we connect?
Luc Lapierre (05-26-2019)
  #350
Old 05-26-2019, 12:05 AM
Luc Lapierre's Avatar
Put me on the list too in case the poster above changes his/her mind 😉
  #351
Old 05-26-2019, 08:23 AM
DJS's Avatar
DJS
DJS is online now
Received 2,106 Likes on 1,406 Posts
Takes 5 or 10 posts before you can PM.
  #352
Old 05-26-2019, 09:01 AM
Thanks!
  #353
Old 05-27-2019, 07:02 PM
caviarjag's Avatar
I also have a set. Lightly used, I bought and just never got around to putting them on and the car goes back in 6 months. 17mm. Once Eshin sells his, I can send to anyone else who is interested.
Luc Lapierre (05-27-2019)
  #354
Old 05-27-2019, 07:07 PM
PM'd
Hopefully I wasn't too slow this time 😏
  #355
Old 06-04-2019, 05:50 PM
usgpru27's Avatar
I know you all know this but I wanted to note that Lenny chased after me when he didn’t have too making sure he made the correct spacers for me. Stand up guy! Much appreciated Lenny. Great to have committed suppliers in our court.
Burt Gummer (06-05-2019)
  #356
Old 02-08-2020, 12:31 AM
JasonR2's Avatar
Before I order a set of 17mm spacers, does anyone have a set in need of a good home?
Am I correct that ac17mm spacer won’t require grinding of the bolts for clearance? Any fitment issue with particular factory wheels?
For clarification this Is for a 2015 F-Type with 19” Centrifuge wheels.
Thanks!
  #357
Old 02-09-2020, 02:05 PM
Unhingd's Avatar
Received 4,661 Likes on 3,366 Posts
Thanks!
No grinding should be required with 17 mm adapter’s, but I would place some Plastigage (thinnest available) on the end of a couple of the studs just to make certain.
  #358
Old 02-19-2020, 11:24 PM
EricU's Avatar
Default Storm wheels
I don’t believe anyone ever answered this question after reading entire thread... Do the 15mm spacer adaptors fit the OEM Storm wheels (standard for CCB’s) without grinding the studs?? Or do I have to order the 17mm spacers? Thank you in advance.
  #359
Old 06-03-2020, 10:44 AM
dsprague27's Avatar
Hey everyone,
I'm going to order the spacers and just want to make sure I'm getting the correct ones. I'm going with the 17mm but wanted to confirm I should get the 'Design3' that has the pressed in studs with lug nuts attached?
Also, will I need any other hardware to install these?
Thanks!
  #360
Old 06-03-2020, 06:27 PM
dsprague27's Avatar
Also, follow up question; has anyone staggered the spacer sizes? Wondering if 17mm front and 19mm rear would work. If possible, would the 19mm require any modification to fit appropriately?
Quick Reply: Group Buy: (4) 17mm hubcentric adapters/spacers
