Group Buy: (4) 17mm hubcentric adapters/spacers
Old 06-29-2016, 05:52 AM
Foosh's Avatar
Received 1,028 Likes on 854 Posts
Originally Posted by Tel
..and I have heard from Lenny that they will be anodised Black! Sweet!
Can someone remind me of the lug nut torque for the spacers, AND the torque for the OEM lug nuts please?
Does anyone still use a light smear of Copperslip on the threads these days or has that gone out of fashion now?
92 ft/lbs. is the F-Type DRY torque spec.
Please note that "dry" means do not put any type of lube or anti-seize compound on the threads. Any lubrication will dramatically increase the amount of torque necessary to get the lugs to a proper spec, and 92 ft lbs. will no longer be the proper spec.
Tel (06-29-2016)
  #82
Old 06-29-2016, 06:25 AM
Tel's Avatar
Tel
Tel is offline
All copied - Thanks.
Is it 92ft/lbs for the adapter plate lug nuts as well?
  #83
Old 06-29-2016, 06:31 AM
Foosh's Avatar
Yes.
I would also take the wheels off after a few hundred miles, and re-check the torque of the adapter plate lugs.
  #84
Old 06-29-2016, 12:35 PM
jf1's Avatar
jf1
jf1 is offline
Very happy about this! The silver ring showing behind the wheel was my only reservation...
  #85
Old 06-29-2016, 12:38 PM
polarisnavyxj's Avatar
Nice...
Never knew about the availability of the black anodization from Motorsport until now. Sorry for the confusion because the pictures I posted were in silver.
Just confirmed the spacers will indeed be anodized with a flat black finish
In my opinion, I'd clearly say the adapter color should be flat black and definitely match the hub and not stand out like a non oem add-on.
If anyone prefers their set to remain in the natural aluminum finish, please let Lenny know ASAP and he will not anodize your set.
  #86
Old 06-29-2016, 01:29 PM
That's a good point, can we use the permanent loctite for extra safety for the adapters if we plan them as a permanent add-on? I see no need to ever remove them other than if we were to get some custom wheels that then we could toy with the offsets.
Am I missing any reason we should ever need to remove these other than failure?
  #87
Old 06-29-2016, 02:22 PM
jf1's Avatar
jf1
jf1 is offline
I would think you'd need to remove the spacers to replace brake rotors at a minimum.
  #88
Old 06-29-2016, 02:43 PM
Unhingd's Avatar
Received 4,661 Likes on 3,366 Posts
92 ft-lbs (125Nm) on both (same stud size). And yes, use something similar to Never-Seez (silver colored copper & graphite goo). Otherwise you can't torque it properly and you run the risk of not getting it back off without penetrant and an impact wrench (locations with real weather). Thread deformation at the appropriate torque will lock the lug nuts in place. Jag does not specify that torque as a dry torque. The Mark's Mechanical Engineering Handbook concurs with my approach. (and 4 decades driving & 1.5 decades of racing experience). Always results in the same torque required to take them off as to put them on. That can't be said about the dry approach.
The following 2 users liked this post by Unhingd:
JgaXkr (06-30-2016), Tel (06-29-2016)
  #89
Old 06-29-2016, 02:46 PM
Unhingd's Avatar
Yes.
+1.
  #90
Old 06-29-2016, 02:47 PM
Unhingd's Avatar
Yes, if you ever need to replace the rotors...and you will.
  #91
Old 06-29-2016, 03:26 PM
OK, I'm not a mechanic but are you saying both a brake job and a rotor replacement you would need to remove adapter? Rotors I can see, but pads?
There are at least two versions of Loctite, permanent and temporary. You're referring to a copper grease for easy threading. Our purposes are diametrically opposed. I'll use what you suggest.
  #92
Old 06-29-2016, 04:25 PM
cptslow's Avatar
Made it in guys. Thanks for the help.
  #93
Old 06-29-2016, 08:47 PM
Unhingd's Avatar
The pads can be replaced without removing anything but the wheel. However, the steel on those rotors is soft enough these days that they need to be replaced whenever the pads are replaced. BMW rotors (including the MINIs) all need replacement with the pads, and those rotors are from the same vendor as the F-Type's.
  #94
Old 06-29-2016, 08:52 PM
Are you F serious?
This I didn't F know!
New rotor overtime you need pads...when did the car makers drop this F bombshell on us? How did I F miss this?
  #95
Old 06-29-2016, 09:23 PM
Unhingd's Avatar
Are you F serious?
Serious as a heart attack. For my MINI, since the beginning (2002). Other Bimmers earlier than that. Weight saving issue. They don't put enough meat on new rotors anymore to make it possible to turn them.
  #96
Old 06-29-2016, 09:26 PM
I will get some sweet cross drilled, slotted rotors at first sign of failure,
  #97
Old 06-30-2016, 09:51 AM
Mahjik's Avatar
It's rare that a rotor "needs" to be replaced when brake pads do.. You should request a measurement of the rotor to ensure they are indeed worn below the manufacturers minimum width requirement. You also do NOT need rotors turned when you change brake pads.
  #98
Old 06-30-2016, 10:22 AM
This is what Ive always thought but Unhinged would know.
Rotors ere covered under warranty or is this considered driver fault?
  #99
Old 06-30-2016, 10:34 AM
Unhingd's Avatar
Generally, that is correct, but no longer true on German cars.
  #100
Old 06-30-2016, 10:35 AM
Unhingd's Avatar
You'll have to read your warranty.
Quick Reply: Group Buy: (4) 17mm hubcentric adapters/spacers
