Group Buy: (4) 17mm hubcentric adapters/spacers
#102
Yes. Brand new they are within just a few thousandths of an inch over the minimum specs. BMW purposefully builds and specs them to require replacement at the first pad replacement.
#104
Dunno . Certainly a problem with the '02 and '09 MINIs, and the service advisors mentioning it as common among all BMWs. Maybe it's the way I drive.
Mahjik (06-30-2016)
#105
I did all the brake maintenance on my M3, so I was pretty meticulous about about the wear (and I measure my brake pads and rotors after every event on my race car). I would definitely have the shop show the measurements regardless of the car when they suggest to replace rotors just to make sure they do need to replaced (or that they won't make it another brake pad cycle).
Unhingd (06-30-2016)
#106
#108
#110
With the stock wheel to tire gap I don't think it will be an issue, but eorthy of close inspection. If I run into issues, I'll remove the spacers until the 305s are worn out and go back to 295s next time.
#112
Yes, I'm sure 305s will be OK from a clearance and rubbing standpoint w/ even the 17mm spacer at OEM height . . . as long as you don't mind your tires extending a bit beyond the fender lip. The 295s are very close to flush w/ the 15mm spacers, which is exactly why that original spec was decided upon.
#114
#116
#117
#119
Originally Posted by Unhingd
A peeve of mine as well, but you have it backwards:
The V6S generates 339 lb-ft of torque, 460 Joules
The lug nuts get torqued to 92 ft-lbs, 125 Nm
The imperial unit for torque is the product of force x distance, in that order. Hence, lb-ft goes with Nm to match the SI convention.
The United States is the only place in the world where ft-lb is used as a unit of torque, and it is widely accepted but not correct.
In the US it really boils down to having an argument about two accepted spellings of the same word.
But God damn it, canceled has one L.
#120
umm...we kind of strayed from the empire about 250 years ago.
