Group Buy: (4) Motorsport Tech hubcentric adapters/spacers
Old 03-14-2018, 08:22 PM
Unhingd's Avatar
Received 4,661 Likes on 3,366 Posts
Originally Posted by Chester///M
Not so happy with the look of the drop with AP springs. It's not low enough and the front gap still looks big and now much bigger than rear.
It certainly doesn't look right. Does it look the same on both sides? Drive it around on some bumpy roads for a few days, they may settle in. Confirm with Stuart that he sent you the right springs. There's 2 or 3 different sets depending on the model.
  #242
Old 03-15-2018, 12:08 AM
SVR's Avatar
SVR
SVR is offline
Can others confirm that 17mm spacers will not require any cutting? I have a pair ready to go on the rear...when I get the car car back from the dealer for a broken wheel stud.
  #243
Old 03-15-2018, 09:15 AM
Tork Monster's Avatar
SVR- It may depend on which wheels you are running. I cut my studs because I measured only ~1.5mm (<1/16") clearance between the pocket depth in my rims (20" Gyrodyne) and the top of the uncut studs after the spacers were installed. They probably would have cleared fine, but I felt better trimming the length to make sure.
However, Watson6505 didn't clear even after he cut his studs down for 15mm spacers and Cyclone wheels (see above post).
Jay
  #244
Old 03-15-2018, 10:38 AM
Chester///M's Avatar
Thanks, I'll try that. The drop is consistent on both sides and the front is just shy of 1.5" while the rear is closer to 1".
  #245
Old 03-18-2018, 02:57 PM
watson6505's Avatar
Default Out of hibernation
Well, even without the spacers installed I went ahead and changed over from 19" propellors with PZeros to 20" powder coated cyclones and MPSS. I wish I had a little more light in the pictures, but you should get the idea. I drove home with the radio off and felt/heard a tiny clank coming from the rear like something was rolling around in the trunk (but there isn't). I don't think it has anything to do with the tire, but its a little concerning...maybe brake pad movement that I never really listened for before.
Might sell the propellors, haven't decided yet...in the middle of lifting my 4runner and getting new tires so maybe these wheels can fund that.
Before:
After:
  #246
Old 03-18-2018, 03:40 PM
Unhingd's Avatar
Check to see if the lug nuts are properly torqued.
  #247
Old 03-18-2018, 03:43 PM
watson6505's Avatar
I watched them torque them, but I will certainly check...seemed most noticeable when slowing down or when shifting into gear from park.
  #248
Old 06-12-2018, 11:33 AM
vettegood's Avatar
Hello, has anybody that ordered the 17mm spacers decided to not use their spacers?
I need two 17mm black spacers, since i had to donate two of my spacers to my wife's jaguar.
I bought her her new wheels and the rear wheel was rubbing on the inside wheel well so i used two spacers to push them out.
Now i need two more for my f-type. anybody have two black 15mm or 17mm spacers not being used?
If not i will have Lenny make me two more. i course i will pay for them.
Thanks and Happy Motoring,
Mitchell
  #249
Old 06-12-2018, 12:50 PM
NJ68's Avatar
HI, I am just about to but up for sale (QTY 4) for $150 (buyer pays shipping, what ever that cost is..) of the the Black 17mm previously purchased form Lenny (Motorsport-tech) for the F-Type - Never used or taken out of the box.
Let me know if you interested....
Ralph
The following 2 users liked this post by NJ68:
Burt Gummer (06-12-2018), Dubzeey Wu (08-08-2019)
  #250
Old 06-12-2018, 02:46 PM
vettegood's Avatar
A perfect example of the forum working for everyone. NJ68 selling, I was looking we made deal happen. he's in New Jersey, i'm in Ariz. would never of happened without the Forum.
Thanks Jaguar Forum!
Happy Motoring to all,
Mitchell
The following 2 users liked this post by vettegood:
Mbourne (06-12-2018), Panthro (06-23-2018)
  #251
Old 06-13-2018, 04:43 PM
Miauuu's Avatar
So it seems after reading this thread that there are two issues:
The 15mm studs too long..
The 17mm rub on stock suspension w/295 tires.
What's the best alternative then? I don't want to grind studs or deal with rubbing issues.
  #252
Old 06-13-2018, 06:18 PM
lizzardo's Avatar
The 17mm rubs.
What's the best alternative then? I don't want to cut the studs nor deal with rubbing issues.
Other than not installing adapters at all? There was talk a while back, maybe in this thread, of how thick a spacer could be used that was an actual spacer, not an adapter. There's no guarantee that the 17mm spacers will rub, as it depends on springs and wheels/tires.
  #253
Old 06-13-2018, 07:29 PM
Unhingd's Avatar
+1. 17mm will likely work as long as you don’t upsize the tires to the 305s in back. However, with some of the OEM wheels you may still have to do a bit of stud grinding.
  #254
Old 09-05-2018, 09:07 PM
Jaggyx's Avatar
If anyone is interested, I've got a set of 4 of these in 15mm black that I ran on my car for about 2 weeks. Just bought wheels that will no longer require them, so they're up for sale. PM me!
  #255
Old 09-05-2018, 09:44 PM
Greggbhill's Avatar
i’m curious... which wheels did you get?
  #256
Old 09-05-2018, 09:45 PM
Jaggyx's Avatar
Bought FR500GT's Niche wheels he had for sale.
The following 2 users liked this post by Jaggyx:
Burt Gummer (09-06-2018), Greggbhill (09-05-2018)
  #257
Old 09-06-2018, 01:13 PM
WJV's Avatar
WJV
WJV is offline
Mitchell
https://www.jaguarforums.com/forum/market/207575
  #258
Old 03-21-2019, 02:32 PM
Since I bought new 21" wheels with custom offsets, I am selling my 17mm spacers I purchased in this group buy.
I am posting a link here, as I rarely surf the marketplace. Please advise if this is not allowed.
https://www.jaguarforums.com/forum/market/215342
  #259
Old 03-21-2019, 09:00 PM
xxaarraa's Avatar
I can confirm that 17mm spacers with STOCK girodyne REAR wheels in an ftype-r did NOT need any trimming. Look great to me.
Tork Monster (03-21-2019)
  #260
Old 08-08-2019, 03:44 AM
Dubzeey Wu's Avatar
Ralph
Still available?
Quick Reply: Group Buy: (4) Motorsport Tech hubcentric adapters/spacers
