Group Buy: (4) Motorsport Tech hubcentric adapters/spacers
#262
#263
OEM springs? If so, you might never load the suspension sufficiently to experience full spring compression. You would, however, have severe tire rub under that condition. With a lowered suspension you would definitely need to drop back to a 10-12 spacer which can’t be done without installing longer studs.
#264
#265
I have a pair of used 6 mm spacers listed on the Marketplace sub-forum that will push lowered 305’s out close to the limit without compromising thread contact.
Dremorg (08-12-2019)
#266
#267
6mm spacers plus 305 tires will provide the same appearance as an 11mm spacer with the OEM size tires. Not optimal, but the best that can be done with the 305s, given the available spacer options.
#268
IronMike - I see that you have the 20 inch Storm Wheels for your 2015 Jag F Type R. I have these wheels too for my 2015 Jag F Type R and I would like to get some adapters. I run 295's in the rear (looks like you have 305's with 15mm adapters in the rear and 17mm in the front). Do you have the Motorsport Adaptec Design #3 adapters? Any rubbing? Did you have to shave or grind for the Storm Wheels to fit?
