Group Buy: (4) Motorsport Tech hubcentric adapters/spacers
Old 08-08-2019, 06:04 AM
NJ68's Avatar
No... they were sold..
  #262
Old 08-08-2019, 05:34 PM
Dremorg's Avatar
Just bought 305’s for the rear. Do I need to remove the 17mm spacers?
  #263
Old 08-08-2019, 09:58 PM
Unhingd's Avatar
Received 4,664 Likes on 3,369 Posts
OEM springs? If so, you might never load the suspension sufficiently to experience full spring compression. You would, however, have severe tire rub under that condition. With a lowered suspension you would definitely need to drop back to a 10-12 spacer which can’t be done without installing longer studs.
  #264
Old 08-10-2019, 12:26 PM
Dremorg's Avatar
Haven’t installed the 305’s yet. I have the OEM springs but plan to drop it slightly soon. Guess I’ll have to remove them. Thanks.
  #265
Old 08-10-2019, 04:00 PM
Unhingd's Avatar
I have a pair of used 6 mm spacers listed on the Marketplace sub-forum that will push lowered 305’s out close to the limit without compromising thread contact.
Dremorg (08-12-2019)
  #266
Old 08-12-2019, 09:19 PM
Dremorg's Avatar
So the extra width of the 305’s won’t give the wheels a flush fit with the fender? Make up for the 17 mm spacers? I’d still need spacers huh? If so, I’d take them off your hands.
  #267
Old 08-12-2019, 09:54 PM
Unhingd's Avatar
6mm spacers plus 305 tires will provide the same appearance as an 11mm spacer with the OEM size tires. Not optimal, but the best that can be done with the 305s, given the available spacer options.
  #268
Old 07-06-2020, 04:09 PM
JRS's Avatar
JRS
JRS is offline
IronMike - I see that you have the 20 inch Storm Wheels for your 2015 Jag F Type R. I have these wheels too for my 2015 Jag F Type R and I would like to get some adapters. I run 295's in the rear (looks like you have 305's with 15mm adapters in the rear and 17mm in the front). Do you have the Motorsport Adaptec Design #3 adapters? Any rubbing? Did you have to shave or grind for the Storm Wheels to fit?
Leet8845
02-20-2024 02:52 PM
mv007F
07-09-2023 12:52 PM
Bdogge
01-25-2020 07:07 PM
indietor
01-05-2018 11:57 PM
strippersteel
07-24-2015 12:53 PM
Quick Reply: Group Buy: (4) Motorsport Tech hubcentric adapters/spacers
