Group Buy: (4) Motorsport Tech hubcentric adapters/spacers
Old 01-11-2018, 02:21 PM
watson6505's Avatar
making good progress fellas....we have 6 with first preference being 15mm....and 1 with first preference as 17mm
  #102
Old 01-11-2018, 02:37 PM
indietor's Avatar
Originally Posted by Tork Monster
Burt- Your car is gorgeous!
you can low with eibach i buy eibach only 1,5 cm front and 2,5 cm rear
same for me the roads are not good for h&r
  #103
Old 01-11-2018, 09:23 PM
Burt Gummer's Avatar
Indietor hope this is what you wanted -
Chester///M (01-12-2018)
  #104
Old 01-11-2018, 10:00 PM
vettegood's Avatar
Nice pictures Burt. Ok are these 15mm or 17mm spacers on your wheels? all around?
I suspect 17mm all around. And you have absolutely no rubbing or scraping? ever?
Thanks for your time and the pictures.
and the tires are 295 rear and 255 front, standard OEM tire sizes? did you have to grind/ shave studs?
  #105
Old 01-11-2018, 10:51 PM
17mm all 4
Absolutely no rubbing, ever (that would be a deal breaker for me too)
OEM size yes - 295 and 255
Yes - 20" Gyrodynes had to grind, some wheels don't require grinding.
vettegood (01-11-2018)
  #106
Old 01-12-2018, 12:26 AM
watson6505's Avatar
one comment that I want to add to Burts detailed write-up on grinding the studs is that you "should' screw the lug nut onto the stud BEFORE you cut/grind/etc.... just in case you touch the threads, backing the lug nut can help with any re-threading or thread correction when backing it off.
One thing I also want to ask is that you said you are 'not cutting', .you are grinding'. Are you really not just trying to lop off the non threaded end of the stud? Are you actually trying to grind vs cut?
  #107
Old 01-12-2018, 12:28 AM
indietor's Avatar
can you put a photo of the stud and the part that will be grinded ?
thx
it's important to all i think to understand what we can do
  #108
Old 01-12-2018, 12:29 AM
watson6505's Avatar
lets try to close this list out by the end of the weekend or early next week. We have 7 total, of which 6 have a 15mm preference and 1 17mm preference.
For anyone on the list, please put whether you want them black anodized or not.
For anyone that is a new owner, it may pay to take advantage of the group buy now if you ever have aspirations to get spacers.
1. watson6505 (15, 17) Black
2. itismejoshy (15, 17)
3. vettegood (17 ONLY) Black
4. Donzi38ZXXX (15, 17)
5. Chester///M (15 ONLY)
6. Tork Monster (15, 17)
7. lizzardo (15,17)
8.
9.
10.
11.
Old 01-12-2018, 12:31 AM
watson6505's Avatar
indietor are you jumping into the GB?
  #110
Old 01-12-2018, 12:32 AM
indietor's Avatar
the problem is that im in italy
and want understand if with 19 propeller i need to grind or not
  #111
Old 01-12-2018, 02:36 AM
Unhingd's Avatar
Received 4,664 Likes on 3,369 Posts
thx
The following 4 users liked this post by Unhingd:
Burt Gummer (01-12-2018), Chester///M (01-12-2018), indietor (01-12-2018), Tork Monster (01-12-2018)
  #112
Old 01-12-2018, 02:39 AM
indietor's Avatar
thx ,perfect explanation
now i feel more confident
  #113
Old 01-12-2018, 02:42 AM
OzXFR's Avatar
Received 3,226 Likes on 2,380 Posts
Stoopid question maybe, but if I ever did want to shorten the stud length, could I just cut the tips off with a hacksaw or are they too hard for that? I don't have an angle grinder.
  #114
Old 01-12-2018, 02:59 AM
Unhingd's Avatar
Hardened steel. You'd wear out several hacksaw blades on every stud (if it's even possible). A small angle grinder should cost you less than AU$100.
OzXFR (01-12-2018)
  #115
Old 01-12-2018, 03:21 AM
Gollom122's Avatar
I got mine from Lenny last year 17mm. I think with 15mm you will have to grind down the studs - I am sure this is covered in other threads. Paid $100 to ship to the UK.
  #116
Old 01-12-2018, 07:28 AM
watson6505's Avatar
wow, unhingd is an artist too.
Any comments on screwing the lugs onto the studs prior to grinding. Even if you dont get to the threads they could act as a stopping point
  #117
Old 01-12-2018, 07:29 AM
watson6505's Avatar
Here is the latest:
7. lizzardo (15,17)
8.
9.
10.
11.
Old 01-12-2018, 10:24 AM
Chester///M's Avatar
Originally Posted by Unhingd
Now that's impressive. What kind of grinder is that? Hahahahaha
  #119
Old 01-12-2018, 10:25 AM
Originally Posted by watson6505
Here is the latest:
5. Chester///M (15 ONLY) Black
7. lizzardo (15,17)
8.
9.
10.
11.
Updated.
  #120
Old 01-12-2018, 10:29 AM
Link to cheap grinders @ HF for those who need one (there is one for $11...prolly good for one use, lol):
https://www.harborfreight.com/catalo...rs+and+buffers
Quick Reply: Group Buy: (4) Motorsport Tech hubcentric adapters/spacers
