Group Buy: Lithium-Ion Battery
Old 04-09-2018, 03:39 PM
Gibbo205's Avatar
Originally Posted by Unhingd
Gibbo, you win. The AG battery is a full half inch taller than the OEM battery, and too tall to permit anything other than the OEM tray to be installed. I have employed the same installation methodology as you, and will have pics later today. They won’t look much different than yours. The retaining Rod, however, does require a 1/2 inch spacer at the bottom with a 10mm longer bolt.
Yeah that is what I did, just used spacers and slightly longer bolt, works a treat, took the car for a mad drive, corner carving, hitting brakes hard, zero noise or movement from the back.
My stock battery weighed 25.9kg on my scales, the RS30 was 4.6kg so the saving is good. I also removed the tyre gel, the inflator and have not bothered with the lid to battery compartment, just kept the main cover. As such I am about 25kg out the car from battery swap.
I also noticed the entire rear of the car seems to have specially cut foam inserts under the carpets, I assume this is to maintain the carpet shape? I doubt it weighs anything, just never had a car that had so much foam in the rear.
2PC brakes should get installed this week, so that is close to 50kg removed. Question is now, where else can I reduce weight in this car, any other hidden parts that can be removed or parts replaced for lighter components? My wheels are not too heavy been the SVR forged wheels so would be pretty pointless messing there and no doubt very expensive.
  #122
Old 04-09-2018, 07:22 PM
OzXFR's Avatar
Received 3,217 Likes on 2,372 Posts
I reckon those foam inserts in the rear are for both shaping and noise insulation.
I loosened off the panels and took mine out to prepare for fitting the VAP springs (they fit right over the top strut bolts), but without taking the panels right off there was only just enough room to get them out and I ended up breaking the RHS one in half anyway!
Yes, they weigh bugger all, I wouldn't bother removing them unless you need to access the top strut bolts.
  #123
Old 04-10-2018, 04:32 AM
Unhingd's Avatar
Received 4,661 Likes on 3,366 Posts
I am having a lightened flywheel designed and built as we speak for the MT. The OEM flywheel weighs in at 38 lbs. They should be able to bring the new one in under 18 lbs. They also expect to cut the weight of the clutch by a few lbs as well. This project is being done to resolve the questionable OEM clutch and to change performance characteristics of the engine more so than to reduce vehicle weight.
  #124
Old 04-10-2018, 05:32 AM
Gibbo205's Avatar
Just a word of advice with flywheels, do not go too light, the reason some cars run quite heavy flywheels is for dampening harmful vibrations, so they make them heavy for longevity of other components, also if its too light it could make the car not as nice to drive.
So definitely make sure you working with someone who really knows what they are doing, but yes if done right a lighter flywheel and lighter drive shaft can really make a difference in how a vehicle revs and of course have a good impact on acceleration, I've know people gain upto three tenths in quarter mile with a flywheel and driveshaft combination.
  #125
Old 04-10-2018, 03:56 PM
Unhingd's Avatar
Here's the final installation. That thing ain't goin' nowhere. Except for one bushing and 1 extra length bolt for the tie-down rod, everything is left OEM.
mlebofsky (04-10-2018)
  #126
Old 04-11-2018, 07:54 PM
Unhingd's Avatar
For those of you interested in the AG LS-30 battery, parts you will need is:
1. M8-1.25 x 30mm bolt
2. 3/8" (10mm) spacer. (you will probably have to drill out the hole to 3/8' or 10mm)
3. 8"x14" piece of black foam rubber drawer lining (
https://www.amazon.com/Duck-284148-Clorox-20-Inch-6-Feet/dp/B010DHSV6O/ref=sr_1_6?s=kitchen&ie=UTF8&qid=1523480884&sr=1-6&refinements=p_n_feature_twenty_browse-bin%3A3254098011 https://www.amazon.com/Duck-284148-Clorox-20-Inch-6-Feet/dp/B010DHSV6O/ref=sr_1_6?s=kitchen&ie=UTF8&qid=1523480884&sr=1-6&refinements=p_n_feature_twenty_browse-bin%3A3254098011
  #127
Old 04-12-2018, 07:14 AM
Unhingd's Avatar
Anti-Gravity just raised the minimum price that their dealers can sell the batteries by $50 to $680. Billet Proof is checking to see if AG will let him honor the $630 on the group buy. Please let me know if you want in at $630. The order would have to go in as a group order all at the same time.
  #128
Old 04-12-2018, 08:54 AM
Chawumba's Avatar
I'm in - $630 beats $680.
  #129
Old 04-12-2018, 02:15 PM
Unhingd's Avatar
I’ll keep you posted.
  #130
Old 04-12-2018, 05:09 PM
RGPV6S's Avatar
I have been reading this thread with interest but was wondering if it is a good idea to put a LiPO battery in a car. If a collision were to happen they might catch fire. LiPOs do that on occasion when damaged.
Any thoughts?
  #131
Old 04-12-2018, 07:06 PM
Unhingd's Avatar
Any thoughts?
Certainly a valid concern. Given the legal exposure, I refuse to offer a response on this issue, but refer you to the following article for a full explanation: Safety Concerns with Li-ion Batteries ? Battery University
Suffice it to say, I am sufficiently confident of the technology to employ this technology on my baby. You need to make a determination for yourself.
  #132
Old 04-12-2018, 07:09 PM
Unhingd's Avatar
Default Time to order
Billet Proof has been given the green lite to sell to us at $630 (already got mine at that price). If you want to be included in this deal, pm me your full name, and I will respond with the phone number you need to call to get the $50 discount off Billet Proof's new price.
  #133
Old 04-13-2018, 08:30 AM
DJS's Avatar
DJS
DJS is offline
Received 2,110 Likes on 1,409 Posts
Are you removing a similar weight from the front of the car, to maintain the 50/50 weight distribution?
  #134
Old 04-13-2018, 11:20 AM
Unhingd's Avatar
Will remove bumper (P7 grille going in) and install a lighter flywheel.
  #135
Old 04-13-2018, 11:29 AM
Gibbo205's Avatar
I removed my front number plate, does that count?
  #136
Old 04-17-2018, 07:04 PM
Unhingd's Avatar
Default Last Call
BilletProof will probably close out this offer to us by the end of this month. The $630 offer is 10% off the retail price ($700) and $50 off what BilletProofs web price. If you are interested, pm me your full name so that I can confirm with BilletProof that you are part of this deal.
Lance
  #137
Old 04-17-2018, 09:21 PM
Chawumba's Avatar
Wow, ordered mine yesterday and it was sitting on my doorstep when I got home today! Being used to lead acid batteries, I stressed out for a second as the battery was sitting upside down, but then I remembered the rules have changed with lithium. This baby is light. Gotta believe as the costs come down this will become standard in most cars.
Now I have to get smart about what you guys did to install this....
  #138
Old 04-17-2018, 09:28 PM
Unhingd's Avatar
I got extras of the 3 bits you need (see post #126) and I can send them to you.
This is the rubber padding I now recommend (less costly because it comes in smaller rolls):https://www.ebay.com/i/391766389836?chn=ps
  #139
Old 04-29-2018, 01:46 PM
Chawumba's Avatar
Default Love the new technology
Installed my RS-30 today. 30 mins, using velcro, longer bolt and 3/8 inch spacer and installed without issue. Came with 2 sizes of negative terminal posts, the larger one was perfect for the F type. Ridiculously lightweight, restart technology, and cool LED status lights, almost seems worth the price of entry.
As a bonus, for those with 2015 models, its worthy to note that the silly eco stop start battery weighs almost the same as the new antigravity starter battery, which means I effectively removed the entire 58lb weight of the factory starter battery from my car with one simple upgrade!
Can't wait for the new lightweight rotors (-50lbs), combined with existing forged wheels (-40lbs), battery (-55 lbs) VAP springs and exhaust (-20 lbs) engine cover/misc (-10lbs) my car will be down from 3850 to 3675 lbs. Still too heavy, but 605 horsepower can make up for at least some of that excess weight
Attached Thumbnails Group Buy: Lithium-Ion Battery-img_5627.jpg   Group Buy: Lithium-Ion Battery-img_5626.jpg   Group Buy: Lithium-Ion Battery-img_5625.jpg
  #140
Old 04-29-2018, 02:53 PM
Gibbo205's Avatar
Those now with RS 30 when you press battery status, how many blue lights do you get, mine was 2 when I got it, still 2 now. Just wondering what others have got?
Quick Reply: Group Buy: Lithium-Ion Battery
