Group Buy: VS Forged Wheels
Old 05-29-2019, 06:27 PM
Bray's Avatar
Originally Posted by jaguny
Lance, I would hope these guys could get it right, having done shop drawings (hopefully overlaid onto a section cut of the wheel setup). They did do the other f type I and Tork posted photo of, but that had CCB brake package. They are guaranteed fit, so if they are wrong, I will need to get a new set of fronts. Jut looking at the photos and comparing to the BRG CCB f type, it appears my rears are more concave, although that just may be an illusion.
How did you know which offset to choose? My specs currently for my f type are
295/30zr20 101w in the back
255/35zr20 97w in the front for tires
Rims 9x20 in front 5x108 bolt pattern
Rims 10.5x20 in back 5x108 bolt pattern
  #162
Old 05-29-2019, 06:54 PM
Unhingd's Avatar
Received 4,664 Likes on 3,369 Posts
101 and 97 are tire load specs, not offsets. The OEM offset is 55mm in front and 38mm in back. You can safely reduce each of those by 15mm to get the wheel more flush with the fenders. Some of us went with wheels that were 1/2” wider than stock. That requires a recalculation of the offsets.
  #163
Old 05-29-2019, 07:04 PM
Bray's Avatar
Thank you very much for your response! I appreciate you helping me out!
  #164
Old 05-29-2019, 07:36 PM
Bray's Avatar
Just got off the phone with Paul and purchased the VS07 set in brushed bronze. He said a 35mm and 24mm offset. Is that okay or too much?
  #165
Old 05-29-2019, 07:48 PM
Unhingd's Avatar
If those are offsets for 9” and 10.5” wheels respectively, that will work (and look good).
  #166
Old 05-29-2019, 09:01 PM
Tork Monster's Avatar
Mine are +32mm front; +25mm rear. I have no issues, no rubbing at all (21" diameter), but I would not go with much less offset than that.
1mm less offset in the rear would barely be measurable (1mm<1/32"), and the front is about 1/8" further out than mine. You can see the fitment in the photo below. You should be okay if your wheels are the same widths (9" front, 10.5" rear)
The following 3 users liked this post by Tork Monster:
Burt Gummer (07-13-2019), Panthro (12-16-2019), TheDrainPlug (06-19-2024)
  #167
Old 05-29-2019, 09:06 PM
Bray's Avatar
Do you recommend getting the wortec rotors as well?
  #168
Old 05-29-2019, 09:18 PM
Bray's Avatar
[QUOTE=Tork Monster;2077771]Mine are +32mm front; +25mm rear. I have no issues, no rubbing at all (21" diameter), but I would not go with much greater offset than that.
Thank you for the info! You're car looks great! I like the lowered look too, it definitely makes a difference in the look, you said you installed AP-Velocity progressive rate springs? Does it also make a difference while driving?
Tork Monster (05-30-2019)
  #169
Old 05-29-2019, 09:48 PM
jaguny's Avatar
Here is the wortec group buy thread. I didn't buy them but would consider it in the future when funding allows. Others can chime in on how they like them. They are expensive, but for the right reasons.
https://www.jaguarforums.com/forum/f...f-type-197525/
  #170
Old 05-29-2019, 10:01 PM
DJS's Avatar
DJS
DJS is online now
Received 2,148 Likes on 1,438 Posts
Make sure you have the Super Performance Brakes if looking at the Wortecs.
  #171
Bray's Avatar
Thank you once again! Dang it I missed all the group buys lol still am thankful for all the knowledge and help you have all provided
  #172
Old 05-29-2019, 10:05 PM
Bray's Avatar
I just purchased the AP-Velocity progressive rate springs as well
  #173
Old 07-08-2019, 03:28 PM
Jaggyx's Avatar
Thanks to everyone's help with the offset information in this thread. I just pulled the trigger on some BC Forged EH181's. Although the finish below could have looked great on a black car, I went a bit more conservatively and opted for a brushed clear finish.
20x9.5 ET41
20x11 ET29
The following 4 users liked this post by Jaggyx:
AaronLin (07-09-2019), jaguny (07-09-2019), JgaXkr (07-08-2019), Tork Monster (07-08-2019)
  #174
Old 07-09-2019, 08:30 AM
AaronLin's Avatar
Default Brushed Clear is superb....
20x9.5 ET41
20x11 ET29
BC Forged has the thickest clear-coat
  #175
Old 07-09-2019, 05:40 PM
jaguny's Avatar
Jaggyx, great choice. I see you went with monoblocks. Will be lighter than two piece. Post photos when on.
  #176
Old 07-10-2019, 12:43 AM
Jaggyx's Avatar
Yes, the BC Forged brushed finishes look really good.
Thanks -- cannot wait!
  #177
Old 07-12-2019, 03:23 PM
Jaggyx's Avatar
Those with aftermarket wheels, did you guys have to purchase any specific valve stems to accommodate the TPMS sensors?
  #178
Old 07-12-2019, 03:47 PM
jaguny's Avatar
I think the installer provided new TMPS sensors. I may have the box in the trunk of the car the sensor came in. I can check on Monday. Car still at the office.
  #179
Old 07-12-2019, 10:49 PM
Unhingd's Avatar
Valve stems are an integral part of the TPMS sensors. Any TPMS sensor will fit the wheel. The critical issue is to ensure that the sensor is compatible with the F-Type TPMS. That will differ depending on model year.
  #180
Old 07-13-2019, 06:00 PM
Jaggyx's Avatar
I'll be using the same TPMS sensors now, so non issue in terms of figuring out which frequency I require. I'm sure the installer will have TPMS valve stems so I'll go from there.
Quick Reply: Group Buy: VS Forged Wheels
