Gyrodyne wheel specs
abhishriv (07-14-2017)
Yes, however you must grind the stock wheel studs down about 2mm.
They are 'domed' out EOM w/ an M stamp. Grind them to flat and that should do it. Easy job with a Dewalt handheld grinder.
Without doing that with the Gyrodynes and 17mm spacers, the factory studs will grind against the backside of the wheel and you will have two indications of that happening. Wheels act unbalanced on the road + you will hear a whoosing sound upon driving slowing in quiet area (like in a parking garage).
Grind first and don't believe the they fit w/o any issues misstatements on the spacer thread.
Does not matter if you lower or not. 17mm spacers with a 305 tire will result in fender rub under routine driving conditions.
+1. With 305s in back I had to lose the 15mm spacers and use 6mm instead. Ideally would have used 10mm spacers, but that requires longer studs. When the 305s wear out, i'm reverting to the 295s with 15mm spacers.
What's the widest spacer available that allows the stock lugs to be safely used? I also have 305s in the rear.
I chose the 6 mm spacers and personally wouldn't go beyond that for safety reasons. That pushes the tire sidewall out just 4 mm less than a 15mm adaptor with 295s. I couldn't see the difference.
FS[MidWest]: 20" Gyrodyne Black & Diamond F-Type Wheels For Sale
F16
07-24-2016 11:14 AM
schraderade
06-06-2014 06:48 AM
AGLXTYPE
12-23-2007 06:47 PM
