H&R 15mm spacers?...
Hi guys...I pulled the trigger and ordered H&R lowering sport springs for my '16 S convertible. I also ordered the 15mm spacers (part # 3035634 SW) ....I ordered the spacers based on my tuner shops advice.... however, just to be sure (I'm a worrier!) I contacted H&R and they said they DO NOT produce spacers for my car...I believe the ones I ordered are specific to the XF but also will fit the F Type? Can anyone who may have used H&R spacers shed any light on this??
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
Received 3,226 Likes
If they fit the XF they will also fit an F-Type as the PCD (5x108) and centre bore are identical.
But beware it seems H&R sell two different types for modern Jags, spacers and adaptors:
Spacers: https://www.bmptuning.com/products/3035634sw
Adapters: https://www.ecstuning.com/b-h-and-r-...-pair/3035634/
You want the adapters (drm - second link above) NOT the spacers (sw - first link above).
The confusion arises because generically (ie not just H&R) both are called spacers and both are called adapters although they are very different things.
Rat Fink65 (06-06-2024)
Rat Fink65 (06-07-2024)
Burt Gummer (06-12-2024)
Yes, unless you have the one and only OEM F-Type wheels which fit with 15 mm spacers - Blade wheels.
Lucky for me that is what I have!
RF65 - tyre size is irrelevant, it's all about the spaces/voids in the back of the wheel between the lug holes.
