H&R Lowering Springs on Base F-Type
#41
I believe they only make one part number for the V6 springs.
https://eibach.com/us/i-7871-pro-kit...4-springs.html
Do some shopping around though. They can be had for much cheaper than $600.
https://www.tunershop.co.uk/suspensi....html?limit=24
#42
#43
#44
Doesn’t matter what springs you have: if you hit a big enough bump with 305 tires and 15mm spacers , you’ll grab the fender lip.
#45
#46
#47
Thanks for the feedback guys, im not a high speed driver, so its more the look i want, if worse comes to worse I can remove the spacers and see what happens, jaggyx your drop is what i am looking for, the front might not drop anything due to the lighter engine, there might be a discounted set of springs available if it dosn't work, will give it a go anyway.
#48
Even hitting freeway dips at 60 mph will cause the rub. That being said, I since have cut the rear spring half a coil as the coils at the top do not provide anything other than spacing. If I were to do it again, I'd probably go with H&R springs even though you do give up some initial travel.
#49
The following 2 users liked this post by Jaggyx:
lossking_ (05-02-2020),
powerhouse (11-06-2019)
#50
Stuart@VelocityAP
04-26-2024 12:38 PM
Stuart@VelocityAP
07-19-2015 09:14 PM
Stuart@VelocityAP
09-04-2014 10:39 AM
